How do you make a bright-sounding Pro-ject turntable sound softer?
3 replies [Last post]
Milesmal25
Milesmal25's picture
Hi, I've just purchased some 2nd-hand Wharfedale Pacific Pi-40 speakers. I have an NAD C370 amp and an NAD C541i CD player, with Chord Odyssey 2 cables (bi-wired.) I am very satisfied with the sound I'm getting. However, I have a 2nd-hand Pro-ject turntable (I think it's a P12) which is known to be on the bright-side. My amp is pretty neutral, but with the bright-sounding speakers (which sound good with my relatively warm-sounding CD player and neutral amp,) and the turntable combined, the combination is just too much. I really don't want to spend much money on upgrades (the turntable cost me £15 and I used some parts from my old faulty Pro-ject Debut 2 SB to get it working perfectly.) What is the best way of trying to get a warmer sound out of the turntable? I've just ordered an Isokinetik acrylic mat for it, but would there be a cheap cartridge that would help do the trick? Or should I try using the tonearm off of my old Pro-ject turntable with the standard ortofon cartidge (which brings me to the question- why does the P12 sound bright in the first-place?) Anyone's informed assistance would be greatly appreciated. Thanks.
Henley
Henley's picture
Re: How do you make a bright-sounding Pro-ject turntable sound s
That's a hard one to answer as there has never been a model called the P12 and, to be fair, there has not really been an issue with products being bright.
Let's assume you have an original pro-ject 1, if you need to make this sound warmer, you could use a rubber platter mat or change the interconnects for a less revealing cable. If you do have a Pro-ject 1 then use this arm as it is better than the one fitted to the Debut.
chebby
chebby's picture
Probably referring to the Project 1.2 (Comfort) turntable ...
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Milesmal25
Hi, The turntable is one of the early Pro-Ject ones as it has the old logo on the lid (it was sold to me on E-Bay without the model no.) It's definately not the 1.2- I did see another listed on E-Bay a few month ago and the model no. began with a "p" and the seller stated it was a bright-sounding turntable- which mine is. About 12 years ago I remember reading about a Pro-Ject turntable review stating it was bright-sounding, so there's no escaping it! I'll try the acrylic platter when I get it and see if this helps. Thanks everyone.
