19 posts / 0 new
Last post
stevebrock's picture
Last seen: 27 min 57 sec ago
Homemade cleaning fluid for Knosti record cleaner
Got myself one now along with some Nagaoka Anti-Static Sleeves.
Been cleaning a few records now with quite good results, however the fluid had been used up!
Anybody got any good homemade recipes?
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
DIB
DIB's picture
Last seen: 2 days 22 hours ago
RE: Homemade cleaning fluid for Knosti record cleaner
When I had a Knosti I mixed up a solution of 1 part Isopropyl Alcohol  with 4 parts distilled water, and a few drops of dishwasher rinseaid.
Did the trick, and works out considerably cheaper than buying Knosti's own solution.
I'm sure there is an old thread from last year on the same subject.
Creek Evolution 50A - NAD C 546BEE - SBT - Epos Elan 30 - NVA cables
Excellent thats the recipe I was after!
Is the Alcohol just a drying agent?
What purpose does the rinse aid serve?
Think I may of clogged my stylus up with the Knosti fluid!
John Duncan's picture
Last seen: 1 month 1 week ago
80/20 distilled water-Isopropyl alcohol with a few mills of ilfotol (photographic wetting agent) which is a bit like rinse aid but without the colouring gunk in it.  Designed to make sure that water coagulates and falls off the record after washing.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
DIB
DIB's picture
Not certain about the rinseaid, it's been a while. I think it was something to stop streaks when you leave the LPs to drain.
Either way, whenever I'd cleaned up an LP I used to give it a good buffing up with a cloth to finish it off. I also invested in a batch of anti-static inner sleeves, and would put the clean LP into one if that album didn't already have one (which was the case in the majority of cases). Once I'd cleaned an LP I never felt the need to clean them again, just a quick once over with a microfibre antistatic brush each time I played it again. I find these days  I look after my LPs 1000% better than I ever did as a lad BITD Laughing
Yes Im using some Nagaoka Anti Static sleeves so have been going through my records, repairing the sleeves covers with a Pritt Stick then cleaned record into a new sleeve......and yes the Anti Stat sleeves work well!
Can you get distilled water from supermarket? Chemist for the Isoporpyl?
DIB
DIB's picture
BIGBERNARDBRESSLAW's picture
Last seen: 7 months 3 weeks ago
I use the same as John, and does the job wonderfully.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
drummerman's picture
Online
Last seen: 4 days 5 hours ago
I dont have a cleaning machine.
I brush a mixture of fresh lime/lemon juice and bicarbonate of soda using a new, good quality soft bristled paint brush into the grooves for a deep, active clean. Leave to work for a minute, brush once more and rinse.
Following that I use a fresh washing up cloth wrapped tightly around the nozzle of a hoover (on low power setting) and simply hoover the water off.
Using a good quality sheet of kitchen roll, the thick type, almost yields the same result as hoovering but I figure if I go to the trouble of washing a record I may just as well finish it properly.
After that, its a new inner sleeve. I dont have many records yet (only just started collecting) but am thinking about writing the cleaning date on a piece of paper. - I can't imagine needing to wash a record more than once every few years, depending on usage so the time taken here is minimal considering.
regards
The_Lhc's picture
Last seen: 3 months 3 days ago
You'll be lucky, I tried several local chemists a few weeks ago trying to get isopropyl alcohol (for cleaning a tape deck but I'd have used it for cleaning records as well), none of them could even order it in. They can get the water though, although most of them had to order it. Never used to be like that, I used to buy the water from my local chemist for cleaning contact lenses.
rjb70stoke's picture
Last seen: 2 years 10 months ago
You can buy Isopropyl Alcohol from Maplin. They sell it as electronic cleaning solution.
We use it all the time at work for cleaning lens elements.
The_Lhc's picture
Interesting, I'll remember that, ta.
Seem to remember it came in spray tins from there, maybe they do bottles as well.
I got mine from local independent chemist, along with the distilled water.  Both in stock at the time.
System burgeoning
Online
I've heard that a few times, not just with that particular 'cleaning' fluid. Kind of defeats wet cleaning. My version leaves no residue on the stylus whatsoever.
I guess it also depends on what stylus is used ie. conical or a fine line which really digs deep into the grooves.
As regards to buying isoprop from Maplins, I find they are very expensive!.
Whilst not the cheapest option (but still cheaper than Maplins) I've ordered the following of Amazon;
http://www.amazon.co.uk/gp/product/B000WGTZ6M/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
I dont use Alcohol on my records but for many other applications, the spray form is convenient and saves waste.
regards
Pages
Log in to post comments
