Help with Set Up
Hi all
I'm after some expert advice on my set up. Currently using a Rega Mira/Fono MC with project carbon arm/Project Xperience TT/Rondo Red.
I've had the rondo red on for a long time (4 years), sporadically used. but way beyond recommended hours usage so thinking of a new cart.
The debate is whether to stick to MC (which is expensive) or go for an MM cart, which my Rega Mira can use without Fono ,sell the Fono and put toward new speakers (currently using ancient AEGIS Ones)
I know there is always a trade off somewhere but will I lose a lot of quality by going from MC to MM?
I guess this is s value question really- would the money be better put toward speakers or maintaining MC cart.
If anyone has suggestions on carts that would also be useful- although I've had the TT a while I've never done any upgrades on it and all the info out there is overwhelming!
- Login to post comments
You could always go to a halfway house - the Denon DL-110 and DL-160 models are MC, but high output so will work with a MM-input.
They are really detailed, excel on timbral reproduction, and the stylus profile manages to avoid a lot of surface noise. I have one on my SL-1210 and it is fantastic.
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
