8 posts / 0 new
Last post
jcarruthers's picture
Last seen: 3 years 3 weeks ago
Gus's subplatter & ME Technoweight
So I did something silly today, two "upgrades" came in the post and I fitted both at the same time.
I don't know if it's the aluminium subplatter, red belt, tighter spindle on the vinyl or the Technoweight but… BOOM
Epic soundstage, immersive, subtleties in the music — brilliant.
Technoweight was a mild faff to fit — and for some reason the dots aren't quite giving me an exact 0.1g as it says. I had to use the mini scales I have to set it up to 2g
James
stevebrock's picture
Last seen: 3 days 8 hours ago
RE: Gus's subplatter & ME Technoweight
hey JC, Ive got Gus subplatter here too, but the spindle is ever ever ever so smaller than the Rega so i have lateral play, when I insert - it drops straight down unlike the Rega one which takes ages. The result of this with the extra play with Gus's its causing some platter wobble. Was your a tight fit? ie did it go down slowly into the housing?
Mine ws a freebie from Gus, so I really need to let him know, i tried to shim it with tape but it didnt work arrggghh
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
Anonymous's picture
Mine was tight but didn't notice much difference from original plastic Rega sub.
Mine is as "tight" as the original.
floyd droid's picture
Last seen: 2 years 8 months ago
James. Pretty much all graduated vtf indicators , be them dots , numbers or baked beans are a rough guide , in some cases very rough !.
I find 2.2g on the dial give me 2.0g on the 10x5 - I have experimented with tracking force but not noticed any difference
S'ok then Steve , just stick another slab on and kick back.
Yeah but this was oddly tricky for some reason — I found it easier to get it bang on 2g compared to the Rega dial — I'll have a play another time.
Log in to post comments
