Feedback Issue
8 replies [Last post]
josbd
josbd's picture
Hello all. I am hoping you can help me.
My set up comprises:
Clearwater Concept TT
Trichord Dino
Roksan Caspian CD Player
Roksan Caspian Amp
ProAc D2s on Partington Broadside stands
Chord Carnival leads
This sits on a 3 stage Atacama Bamboo shelving unit
Speaker stands are filled with Atabytes and spiked, and the shelving is all spiked. Despite all of this, I cannot play an album without reverb/feedback/jumping unless I tiptoe carefully across the floor and sit very still indeed on my bed. I am presuming the floorboards in my room are the problem, but would a couple of paving stones under the shelf unit make the difference, or is it better to invest in a turntable shelf?
I would really value people's opinions on this before I go out at midnight and hoik up a paving slab!
Cheers   beauty, eh
__________________
Roksan Caspian amp & cd; ProAc 2; ClearAudio Concept; Chord Carnival
The_Lhc
The_Lhc's picture
RE: Feedback Issue
How close is the TT to the speakers?
__________________
No signature worth mentioning...
Andrew Everard
Andrew Everard's picture
RE: Feedback Issue
Assuming your walls are solid enough to take one, a shelf could be the answer in sorting out any mechanical feedback – ie through the structure of the room. But it really depends how close your speakers are to the turntable, as you could still get airborne feedback.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
josbd
josbd's picture
RE: Feedback Issue
Thanks for the replies Smile  The turntable is about 10 feet from the speakers. I have two decent solid external walls which should be fine.
__________________
josbd
josbd's picture
RE: Feedback Issue
Also, not sure where my brain was, but my original posting should, of course, have read ClearAudio.......   banging head against wall
__________________
camcroft
camcroft's picture
RE: Feedback Issue
Clearwater Revival TTLaughing
__________________
Marantz SR5023 - Marantz CD5003 - Project Debut Carbon Turntable Black gloss with acrylic platter & Rega Mini phono stage with Atlas Element Integra cables;Monitor Audio RX1 Black gloss Speakers.-Chord Carnival speaker cables.Atacama Nexus 7 speaker stands
Alears
Alears's picture
RE: Feedback Issue
...........I wouldn't give that any creadance! excellent!
My first thoughts would be to check the cartridge tracking weight is correct, or you must have some very dodgy floorboards.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
camcroft
camcroft's picture
RE: Feedback Issue
__________________
josbd
josbd's picture
RE: Feedback Issue
Aargh!!!! Although wincing, badly....  I have to give you cred for those two!!
Cart tracking weight etc, everything is, in fact done for you before each tt leaves the factory........... but naturally this was not enough for one used (as I am certain you all are) to the arcane ways of setting up a turntable. So I had to check it out. The cart tracked at 2.0g. Once I sit down, there is no issue with feedback etc. It is footfall which causes all of the grief. So very dodgy floorboards would appear to be the prob!
__________________
