25 posts / 0 new
Last post
drummerman's picture
Last seen: 21 hours 11 min ago
external phono stage
Although I am very, very happy with my Sony and built-in phono stage, I have now bought another amplifier without built-in stage for a third system.
Has anyone heard or had experience with the following phono stage;
http://www.ebay.co.uk/itm/Project-Phono-Box-DS-in-Silver-Turntable-phono-stage-pre-amplifier-/290951713345?pt=UK_AudioTVElectronics_HomeAudioHiFi_Turntables&hash=item43be12d241
the switchable impedence is a feature I would want on any external phono stage. Not sure what else there is (affordable) that has this option.
The amp in question is a cyrus 8vs2.
regards
Al ears's picture
Last seen: 3 days 20 hours ago
Hi drummerman, the DS is a
Hi drummerman, the DS is a good little device and appears to get good reviews.
However if I were you I'd keep my eye on a Trichord Dino currnently going with a low bid on a certain well-known auction site.
This will serve you better even though you'll need to mess with dip-switches on the underside.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
DandyCobalt's picture
Last seen: 1 year 7 months ago
+1 for the Dino, Drummerman.
RE: external phono stage
Thanks.
I saw it. Looks good but I'm sure it wont go for a few pounds Smile
I'm outspent on hifi this month so may have to let this one slip. We'll see.
Didn't steve have one? RP6 ... Dino ... sounds very familiar.
regards
Al ears's picture
Worth keeping an eye on I'd
Worth keeping an eye on I'd say. If they now go for £388 new you might be lucky to get it for less than the £219 Project. Smile
I'll do that even though the plan was to get the stage with the next pay packet.
You never know.
regards
stevebrock's picture
Last seen: 2 days 17 hours ago
Yes I got a used Dino Mk2 for
Yes I got a used Dino Mk2 for £170 - trashed the Brio R stage, however when I got my Elicit R there was no difference with the Dynavector 10x5 so I decided to move it on - however in hindsight I should of probably just kept it as I know I will try a some Low Output MCs.
I would have no hesitation in getting one again
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
I like the fact you could
I like the fact you could tweak the loading etc - giving more/less bass & treble
If you can stretch to it, the
If you can stretch to it, the one on ebay with separate PSU BIN for £291 might be a better long-term option.
Al ears's picture
Don't push him dandycobalt - the man will end up starving.  :grin:
floyd droid's picture
Last seen: 2 years 6 months ago
RE: Yes I got a used Dino Mk2 for
stevebrock wrote:
Yes I got a used Dino Mk2 for £170 - trashed the Brio R stage, however when I got my Elicit R there was no difference with the Dynavector 10x5 so I decided to move it on - however in hindsight I should of probably just kept it as I know I will try a some Low Output MCs. I would have no hesitation in getting one again
Didn't you find the combination harsh? - The Dino looks good, I have to say. Must do some reading
regards
It's a slippery slope.
ifor's picture
Last seen: 1 week 1 day ago
Do have a look at the Graham Slee range before you spend your money.
"Inspired" Manticore Mantra TT, Technics SL-7 TT, Slee Reflex M phono preamp.  Cyrus CD Xt Sig.  iMac, Raspberry Pi c/w HiFiBerry Digi c/w Volumio or Rune Audio, Arcam rDAC.  Roksan Kandy LIII amp, Spendor A5 speakers.
stevieg330's picture
Last seen: 3 years 3 months ago
Hi Drummerman,
I have the Trichord Dino and think it is a very good phono stage although I haven't compared it to the Rega one. I have also tried the Graham Slee stages, both the Reflex C and the Reflex M with Elevator. Both are extremely good and a step up from the Dino. More detail and realism were the main benefits I felt.
Obviously they are considerably more than the Dino, expecially the combo, so you would expect them to be better but I think for the money, the Dino is great.
HTH
Steve
Thank you everyone.
I am in process of may be buying some Kef References so the stage has to take a back step for a month but failing that (or not) I will take all the helpful advise into consideration.
There is probably a limit to what my turntables/cartridges are capable of so around the £200 mark is probably about the limit for the moment. Having said that, a better one will not limit me in the future.
regards
Pages
Log in to post comments
