16 posts / 0 new
Last post
iMark's picture
Online
Last seen: 1 week 4 days ago
Experience with Henley Designs S/E Upgrade Kit for Pro-Ject?
On the Henley Designs website I found this S/E Upgrade Kit:
http://www.henleydesigns.co.uk/S/E%20Upgrade%20Kit-p841
Since it's a quite inexpensive upgrade, I would consider installing it on our 1Xpression III TT. Any members of the forum that have experience with this kit? Is it worth the GBP 25?
Thanks in advance for any replies.
Pro-Ject 1Xperience Comfort (OM 2Red), Yahama R-N602, Sony UHP-H1, Sony TV, Humax DVR, Infinity Overture 1 speakers. Range from very cheap to expensive cables.
Al ears's picture
Last seen: 1 week 18 hours ago
Have not used it myself but :-
"Measured against the default sound of the turntable and that of my fix, the new system produces a sound that is practically unmeasurable against the sound of the amp and the room."
That might tell you something. However if you are in need of a replacement belt anyway (they don't last forever) then the additional isolation washers for the motor might make it worth investing in. Otherwise just go down to your local B&Q store and pick up a couple of washers for pennies. I am pretty sure the change from flat to round section belt is going to make negligable difference in the resultant sound quality, but like I said if you are in need of a new belt anyway why not try it (it's only £7 dearer).
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
Henley's picture
Last seen: 1 year 4 months ago
In most cases it makes a
In most cases it makes a considerable difference (you must have found one of the few forum posts where this is not the case) but it is dependant on isolation.  However, it also allows you to tune the resonance frequency from the motor to suit your own installation.
The kit is now fitted as standard on Debut Carbon and Exprssion Carbon and the grommets are a custom material designed by Ortofon specifically for this purpose.
UK distributors for Pro-Ject, Ortofon, Roksan, Unison Research, Lehmann and Reloop
Here to help.
The_Lhc's picture
Last seen: 2 months 5 days ago
Henley wrote:In most cases it
That quote's actually taken from your product page for the upgrade given by the OP.
Must admit I'm still not entirely sure what the quote is supposed to be saying...
MajorFubar's picture
Last seen: 3 days 34 min ago
Why do dealers have to put
Why do dealers have to put their business details in their signatures but manufacturers/distributors do not? Even far more than a dealer, who may often post positive personal opinions 'as himself' regarding products he doesn't even stock, some posts by  manufactuers/distributors plainly look like free adverts. Like that one. Let's be honest they're not exactly going to say 'yeah it makes sod all difference, get yourself down to B&Q and buy some washers'.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or RS-180
Al ears's picture
Well spotted, it does indeed come from their own website ..... nice one Henley! laugh
Wasn't too sure of correct interpretation myself but it looked like it was saying it made s*d all difference...
The_Lhc's picture
MajorFubar wrote:Why do
I think it's simply that signatures were lost during the move to the new forum software and infrequent users (Henley only tend to appear every couple of months or so) may not have realised their old sig has disappeared. I doubt there's anything more sinister than that happening.
Al ears's picture
The_Lhc wrote:
Yes I think that is probably it The_Lhc. Everyone lost their sigs when new forum appeared and I know many are unaware of this particularly the infrequent posters.
iMark's picture
Online
Full link
plastic penguin's picture
Last seen: 8 hours 12 min ago
iMark wrote:
iMark wrote:
Actually, that quote comes from a website by a guy called The Apple Chap. Full article here:
http://www.theapplechap.webspace.virginmedia.com/TheAppleChap/Blog/Entries/2011/7/29_Installing_the_new_suspension_set_on_a_deck_with_50_%26_100Hz_rumble.html
Personally I would save the pennies and upgrade the cart at a later date.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
The_Lhc's picture
Yes but it's actually quoted and linked to on the Henley product page for that upgrade (which is presumably how you found it).
For the cost of two large
For the cost of two large pizzas and and a bottle of pop at Pizza Hut you could argue it's worth trying, but how little difference has it got to make before it's deemed as not worth it. £25 buys you a good new LP possibly with some change, or 25-50 used ones from Cancer Research providing your primary taste in music is James Last.
chebby's picture
Last seen: 20 hours 3 min ago
I'm impressed that the pulley
I'm impressed that the pulley is metal and fixed by tightening a grub screw rather than made of (untrimmed) plastic and fixed with a spot of glue.  (You know who I mean.)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
The_Lhc's picture
chebby wrote:
As far as I know all Pro-ject pulleys are metal, certainly have been on all the models I've seen.
chebby's picture
The_Lhc wrote:
Yes, I was comparing with Rega where my old P2 and old P3 both had very shabby looking plastic pulleys secured with a dab of glue. Both had bits of moulding trim left on them too. They were both fine sounding decks and the trim never fouled the belt or anything else, but it looked cheap
Al ears's picture
chebby wrote:
Yes, and their motors used to be held in place by rubber bands. Believe they might have stopped that now though. smiley
Log in to post comments
