6 posts / 0 new
Last post
admin's picture
Last seen: 4 days 7 hours ago
Connecting project2 Xperience turnable to pioneer VSA -AX10i
Dear all
I am still seeking the definitive answer to this question.
I have a pioneer VSXAX10ai with a phono stage earthed input to which I want to connect a moving coil cartridge turntable (Project 2 X perience ). Can some one tell me is it just a connection with the phono leads and earth cable or will I need to connect to another phono input with a separate phono stage because of the low voltage? I ask this as I was told different things by Pioneer & Project technical support.
Regards
Saab
nads's picture
Last seen: 6 months 1 week ago
http://www.whathifi.com/forum
http://www.whathifi.com/forum/turntables-and-lps/connecting-project2-xperience-turnable-to-pioneer-vsa-ax10i
So what was the answer to the question before?
More info needed.
nads's picture
http://www.pioneer.com.sg/sto
http://www.pioneer.com.sg/storefront/manual/VSX-AX10Ai-G.pdf
Page 22 but no mention of MM or MC
Anonymous's picture
RE: Connecting project2 Xperience turnable to pioneer VSA -AX10i
Thanks for your help but I am still looking for the answer.
Regards
Saab:pray:
stevieg330's picture
Last seen: 3 years 6 months ago
Hi Saab,
In the instruction manual for the Pioneer it does actually say MM for the phono input in the specifications.
Audio Section
Input (Sensitivity/Impedance)
PHONO MM . . . . . . . . . . . . . . . . . . . . . . . . 4.7 mV/47 k
4.7mv/47k is more an MM spec than MC as well
Kind Regards
Steve
Anonymous's picture
Hi Steve
Thank you :clap:
Log in to post comments
