cleaning stylus with magic cleaner block
14 replies [Last post]
domenn's picture
I've just found this option how to clean stylus , looks very good and it's cheas as well .
http://www.youtube.com/watch?v=yZWf6tlvVss
just ordered one  Smile    I'll let You know how it works .
__________________
 I Mac , Leema Elements amp-dac , Rega RS5 ,  Chord cables
  Squeezebox touch  ,Leema elements phono stage , Rega P3-24 , Ipad 4
drummerman's picture
RE: cleaning stylus with magic cleaner block
Yes, use that myself. The 'magic' cleaner blocks come in many guises and are very cheap, just one will last for ages. I just cut a small piece off and glue it on a coin. You need to be a little careful with it but it works fine.
regards
__________________
Pretty ... and pretty proud of it
CJSF's picture
A blob of Blu-Tack also work
A blob of Blu-Tack also work well . . .
Al ears's picture
In my experience the white 'Blu Tack' works better.  Smile
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 dac/Tom Evans Groove Anniversary phono amp/Tom Evans Vibe preamp/Linear A power amp/Acoustic Zen Adagios/Chord cables/Oppo 105EU.
CJSF's picture
??? not tried 'white Blu Tack' Al-ears . . . probably because I dont have any.  I did try it as a fixing (very small pea size) for speakers, same as I tried a black version, neither worked very well in the speaker fixing roll . . .  puzzled
CJSF
scene's picture
We've had that stuff in the cupboard for ages. It's almost essential when you have three small boys... Never thought of using it to clean my stylus. May have to give it a go (pre and Post comparison)...
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, Sonos ZP90, AE Compact-1.  AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A.  2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90.  Cables: That Cable HDMI, Chord Crimsons, CAT6 backbone  Sonos S5s in the bedrooms
letsavit2's picture
For a recently divorced bloke such as myself who now has to get his own shopping and cleaning products! what is the uk brand known as?
Edit. Found these in ebay for 2quid?
4 x Magic Sponge Melamine Foam Stain Remover Eraser
__________________
Rega RP3 turntable/Naim 5i CD/Naim 5i amp/Neat motive 2/BK sub
MarantzPM6004/MarantzCD6004/Monitor Audio Bronze BX2
MarantzPM6004/Wharfedale 121
Project Box S/B&W P7 headphones
APX's and a bunch of i things
mikeparker59's picture
Looks like someone has turned this into a product   http://www.ebay.co.uk/itm/Magic-Stylus-Cleaner-record-turntable-cleaner-...
__________________
Heybrook TT2 Linn Basik A&R P77 Marantz PM 6004 Marantz CD6004 Cambridge Audio NP30 Heybrook HB2's, MS Aviano 2 (alternate between these depending on how I feel!!)
A&R A60 A&R T21,Rotel CDP, Mordaunt Short Aviano 1
stevebrock's picture
got mine now, how exactly does it work - after all it a bit of sponge FFS
__________________
Icon Audio ST40 III / KT88, Rega Apollo R, DAC, RS3
Rega RP6, Nagaoka MP-200, White Belt, Michell Tecnoweight, Rega Fono MM
Rega Quattro, Couple 1 & 2
cut a bit off, stick it on a coin or similar solid object, place under the elevated tonearm/cartridge then lower the arm into the sponge two or three times.
Regards
__________________
Regards
yeah I know how to clean it - but actually HOW deos it clean it Smile
__________________
Ah, my pardon Smile
The sponge has micro fibres which act like hooks, grabbing dirt.
Regards
__________________
Cheers Drummerboy......
Cheers Drummerboy...... Genius
How often to use it? Been using it before a session!
__________________
RE: Cheers Drummerboy......
Seen a few posts on this stuff on various forums and Youtube, they also suggest brushing the stylus off after dipping into the sponge to remove any particles that have broken off from the sponge that might be sticking to the stylus.
More detail here    http://www.high-endaudio.com/Magic.html
They are talking about an American product when they talk about the blue layer..... not sure if it exists like that here I've only seen the white stuff in pound shops and on e-bay.
__________________
DIB
DIB's picture
As well as my Ortofon stylus brush, I also use one of these Vinyl Passion Dust Busters, it seems to do the trick nicely.
http://www.ebay.co.uk/itm/Stylus-Cleaner-New-Safe-Easy-to-Use-Polymer-21...
__________________
Creek Evolution 5350 amp with Sequel 40 phonostage -  Creek Evolution 2 CDP - Squeezebox Touch
Pro-Ject 2-Xperience Classic Acryl with 2M Blue
Epos Elan 30s - Van Damme SC & Epiphany Atratus ICs
