Cartridge/Stylus scales (Care to be taken with MC's)
96 replies [Last post]
drummerman's picture
__________________
Pretty ... and pretty proud of it
RE: Cartridge/Stylus scales
http://www.ebay.co.uk/itm/310670058149?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Fantastic little scales. Tiny and seemingly accurate (I took them to a local jeweller which had certified calibration weights). It was out by 0.01g though that could well have been because I forgot to clean the weighing platform before I went there. Probably the weight of a finger print.
Saves quite a bit of money over the dedicated turntable ones though it doesn't measure down to a thousand/g.
Haven't had time to use it on my tables yet but cleaned a new'ish 5pence coin with alcohol (as well as the weighing platform) and it measures 3.25g, exactly as should per Royal Mint. Will keep that as future calibration weight if needed.
regards
__________________
chebby's picture
Online
I was 'old school' and always used the Shure SFG-2.
I still have it in its box in my little 'museum' (box of bits in the under stairs cupboard along with JPW Sonatas and MS20i Pearls and old cables etc.)
It was always far more accurate than the tracking force dials on all the Rega arms I ever used. (Despite being great tonearms, they were shockingly innacurate by as much as +/- 10 percent out!)
__________________
Marantz M-CR603 • Rega R3 loudspeakers • AirPlay • Apple iPad Mini • Apple iPhone 5 • Apple iMac • Apple AirPort Extreme 802.11N • Humax HDR-Fox T2 • Panasonic TX-L32D25B • Sony BDP-S390
Dont get rid of those pearls.
A couple of days ago I played around with my Thorens currently fitted with an Ortofon VMS20E MKII and I listened through headphones adjusting weight (by counter weight) from .5g (!) to 1.5g. The Cart is rated at .75 to 1.25g with 1g recommended.
The Ortofon is known as a good tracker and fits the l/m arm of the Thorens well. I was surprised though at the relatively small difference in sound in that whole 1g range. I expected more. Sure, bass audibly lightened a little but pitch was still discernible. No inner groove distortion or overly pronounced or distorted sibilants at 0.5g and no mis-tracking though the record used wasn't warped etc... . Equally, going above the recommended maximum only slightly subdued high frequency playback with bass now slightly heavier than at the recommended 1g.  - Not better, not worse than going below recommendation but I can see why they recommend the middle, 1g. How accurate my arm counter weight is, dunno but I'll measure properly once I get a chance.
Got a Shure M97ex on order but think I may have made a mistake there as I dont want to loose any high frequencies, one of the problems reported with that cart if loading can't be adjusted (I use an internal phono stage, non-adjustable).
I like vinyl and have gone from none to about 80 records in three months. Expensive hobby though I got some bargains.
regards
__________________
andybeau's picture
That looks like a bargain as I was looking at getting a scale to accurately set up my tone arm/cartridge.
Cheers for that will be buying one
__________________
Rega Brio R, Inspire Quest Rega TT c/w Clearaudio Concept MM, Rega TTPSU, Marrantz CD6004, MA BX2, MF V-Can II, HRT Streamer2, Acer Aspire 1(Win7 Starter), AKG K451, AKG K550, SoundMAGIC HP100
Yamaha RXV671, Sony BDPS370, Xbox360, Samsung UE37E6300, Wharfedale Diamond 9.1, CM10.1, 8.1 SW150
stevebrock's picture
Online
+1
__________________
Icon Audio ST40 III / KT88, Rega Apollo R, DAC, RS3
Rega RP6, Nagaoka MP-200, White Belt, Michell Tecnoweight, Rega Fono MM
Rega Quattro, Couple 1 & 2
Hi-FiOutlaw's picture
regards
Bought on just now!
Thanks for the tip...  Cool
Best REGArds
Me too!
Wonder what reference to check calibration
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic TX-P42G20B., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
regards
... This? Wink
Online
ok so I have ordered one of these!
When i check my cartridge weight, do i put the scale on my platter then lower the tone armon to the scale? or is there a science to it?
__________________
My Rega dealer put the scale on the midle of the platter an low the arm.
DIB
DIB's picture
As is my local dealer. When I had my new 2M Blue fitted last week he used one of these, and he told me he had done for as long as he can remember.
__________________
Creek Evolution 5350 amp with Sequel 40 phonostage -  Creek Evolution 2 CDP - Squeezebox Touch
Pro-Ject 2-Xperience Classic Acryl with 2M Blue
Epos Elan 30s - Van Damme SC & Epiphany Atratus ICs
It also opens up other possibilities such as tonearm/cartridge modifications (or even a tonearm build) where mass is crucial and guessing may not give the results desired.
regards
__________________
Online
Mine have been sent! Should get then delivered tomorrow!
__________________
CJSF's picture
Last year I was laughed at for such attention to detail . . . what is different this year?  You will find the scales give a point of referance to which you can return with confidence.   Changing stylus presure changes the sound, you can set the sound the way you like it.  I found a tad lighter than recomended was best for me.  However, as has been noted, the weight of a 'finger print' can have you running around in circles.  Picking up your referance weight with tweezers helps.
CJSF
floyd droid's picture
Noobs/vinyl engine/tinterwebby =  your posts never existed Cj , simples. So keep looking in Cj as we may learn something ,lol.
Only teasing fellas ,sit on yer digits  Smile.
