Cartridge upgrade for Sony PS11 tonearm
1 reply [Last post]
alanp
alanp's picture
puzzled  Hi,
I think it's about time I replaced the supplied cartridge that came with my Sony ps11 (purchased 1976). I was thinking of something in the Shure range preferably a budget model. Although I don't have a particular one in mind i'm sure it would be an improvement on the current setup. Any suggestions would be greatly appreciated.
nopiano
nopiano's picture
RE: Cartridge upgrade for Sony PS11 tonearm
The only one currently widely available from Shure is the M97xE.  I got mine from the USA for 79USD, but you can probbly get it here too if you hunt around.  Take a look at lpgear.com
It should cope with your Sony, which is probably a bit higher mass than ideal, but the damper will keep the cartridge safe.
Otherwise a basic AT would be a good choice.
http://www.audiotechnicashop.com/index.php?route=product/category&path=9...
Are you OK for fitting it and balancing it?  If not, try to find a nice dealer who remembers how to do it!
__________________
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
