5 posts / 0 new
Last post
Leehallam's picture
Last seen: 2 years 7 months ago
Cartridge Help Please MC/MM
Looking for some help>
I am in the process of upgrading my turntable to a Roksan Radius 5.2, I now need to decide on a cartridge.  I am between the following Goldring 1042, Goldring GL2500, Ortofon Bronze or Ortofon Rondo Red MC.
Any input or advice greatfully recived??
Lee
Al ears's picture
Last seen: 2 days 2 hours ago
RE: Cartridge Help Please MC/MM
As your Rega phono will only work with Moving Magnet cartridges this will somewhat shorten your list.
Unless you are prepared to spend more money on a new phono preamp you are best sticking with moving magnet.
Out of you list I would go for the Goldring 1042 as it will sit well with the Roksan TT and indeed the amp.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
Leehallam's picture
Alears,
thanks for the reply.
i am more than happy investing in a new phone stage if that will give a better result.  I was thinking a trichord dino or a leema elements upgrade for a MM or MC as well.  If the constraint of the phono stage was gone what is the right choice.
thanks for your help
lee
Al ears's picture
It would depend on your budget for a cartridge.
Although I love the moving coils I have had I would say that spending less than £400 on one is a false ecomomy.
If you can do this fine, and I do not use Ortofon cartridges so cannot advise you there, otherwise by the best moving magnet you can get. Have a look at some reviews as there are better ones than the Goldrings you mention.
ifor's picture
Last seen: 1 week 3 days ago
Lee, I saw in another thread that you are planning a home loan of Graham Slee's Reflex C.  You could consider the Reflex M + Elevator which would keep you MM/MC options open.  It might be worth posting this same question on the Graham Slee Forum; I know there re people there with opinions you might find useful.
"Inspired" Manticore Mantra TT, Technics SL-7 TT, Slee Reflex M phono preamp.  Cyrus CD Xt Sig.  iMac, Raspberry Pi c/w HiFiBerry Digi c/w Volumio or Rune Audio, Arcam rDAC.  Roksan Kandy LIII amp, Spendor A5 speakers.
Log in to post comments
