B&O Beocenter 1800 turns too slowly. How can I fix this?
Wed, Oct 24 2012, 8:30PM
I played a record with a very fast paced song on this system today and it sounded a lot less energetic. I checked with the digital version and it was definitely noticeably slower than it should be I'd really like to fix this because I really like the record and it just bothers me every time I hear it slowed down.
I had a look to see if there was a speed adjuster on the system itself and found one, however, it seems to only be for minute changes because the rotation is still too slow.
Should I replace the belt to fix this? Perhaps even have a look at the motor?
I should also mention that it's very old (from the 70s or older) so that will probably have something to do with it.
I would say if its an old or original belt then change it strait away. This will be the most likely cause. Good luck!
