Best phono pre-amp to use with Rega P3-24 - under £250
4 replies [Last post]
roman_sub
roman_sub's picture
What's the best phono stage to use with a Rega P3-24 TT (with Elys 2 cartridge)? Budget approx 250 max.
Thanks!
Roman
mitch65
mitch65's picture
Re: Best phono pre-amp to use with Rega P3-24 - under "250
Graham Slee Gram Amp 2 SE is a great little phono amp at about £225........
__________________
Rega RP6 - Goldring 1042
Rotel RCD 965BX
Sony TA-F700 ES
Naim NAC A5 - Neat Petite
AKG K450 - AKG K551
chebby
chebby's picture
roman_sub:
Rega Fono (Moving magnet) about £165.
Put the change towards the Rega TT-PSU
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
roman_sub
roman_sub's picture
I'll be getting the TT-PSU at some point for sure - however following purchase of Naim 112/150, I'm probably going to go for a Naim Stageline as it seems to be superior to the Fono by all accounts - and within budget second-hand =)
mitch65
mitch65's picture
I picked up a Stageline from a dealer for well under £200 and if you are going down the Naim amp route the Stageline may well be the way to go, the added cost of the i-supply may not be cost effective otherwise . You must do the TT-PSU upgrade as this is a very inexpensive upgrade for the gain in performance.
__________________
Rotel RCD 965BX
Sony TA-F700 ES
AKG K450 - AKG K551
