Best interconnects for vinyl
1 reply [Last post]
jacobmorrison's picture
I've just invested in a pro-ject xperience/goldring 1012GX cart but I suspect the old cambridge audio pacific cables are bringing in some harshness to the sound. I'm using a cambridge audio phono stage so I'm looking to get two sets of cables that will emphasize the analogue nature of the sound, basically something that sounds rich and smooth rather than cold and neutral. Can anybody recommend such a a cable?
Thanks alot.
__________________
Downstairs: Pioneer Kuro 4280 / Oppo 93 / Yamaha RX-V771 / Monitor Audio BR5,BR2,BRLCR / Sky+HD / AppleTV/ Various Sonos
Upstairs: Leema Pulse / Sonos Connect / Musical Fidelity V-DAC II / Project  2 Xperience Acryl - Goldring 1042 - Project SpeedBox II / Monitor Audio  R270HD / Musical Fidelity HPA100 - AKG Q701
Re: Best interconnects for vinyl
Jacob - I really like Chord cables - even their budget end ones Crimson/Chrysalis sounded pretty good to me, detailed without being harsh - although I've mainly got Chameleons in my system now. In almost all cases I picked them up second hand on ebay, much cheaper than normal retail price.
I must admit I was pretty sceptical about cables until I tried out their Chrysalis cable - which was about £30 at the time - think it was the predecessor to the Crimson. Not sure how much you want to spend but if you wanted to start cheap suspect you could pick up a pair of Chord Chrysalis cables for around £20 on Ebay. (NB I use mine on an xperience)
Hope that helps a little
Simon
