Amplifier for Pro-ject Essential
6 replies [Last post]
Ieva
Ieva's picture
I need some help choosing an amplifier for a Pro-ject Essential. I've never used an amplifier and I wouldn't want to spend a fortune on it especially since I am using average speakers (Creative Inspire T3130). Could you recommend me one of these (or any other):
http://www.greenhomeshop.co.uk/shop/index.php?main_page=index&cPath=1&sort=20a&page=1
Also, will the speaker connection fit the amplifier?
Thanks.
The_Lhc
The_Lhc's picture
RE: Amplifier for Pro-ject Essential
Those speakers are active, they already have an amplifier in them, so you can't add another one.
__________________
No signature worth mentioning...
Ieva
Ieva's picture
Thanks. So should I just connect the turntable to the speakers or do I need anything else in between?
The_Lhc
The_Lhc's picture
Ieva wrote:
Those speakers have a power supply yes?
I don't know the Essential well enough to know if it has a phono stage built in, if it doesn't you'll need one, and an appropriate cable to connect it to the speakers.
__________________
Ieva
Ieva's picture
There is a version of Essential with integrated phono-MM preamp and one without. Would the one with the preamp work with those speakers?
nads
nads's picture
Yes as would the one without but you would need a Phono stage ( amplifier).
__________________
Not a HiFi Nut. Just has a pile of Nads.
Ieva
Ieva's picture
I see. Would it make more sense to buy an amplifier seperately then? The price difference between the two (with and without internal amp) is about 100 $. What kind of amp would the best (a good value for money)? Thanks so much for your help.
