Adjusting tracking weight on Bush MTT1?
3 replies [Last post]
PhilD
PhilD's picture
Hiya. Does anyone know how, or if indeed it is possible to manually adjust the tracking weight on the Bush MTT1 turntable? There's nothing in the instructions about it and there doen't appear to be any obvious way to do it...
I've got a new record that skips (a replacement for one that also skipped in exactly the same place, FWIW), one which the guy selling it says plays fine on his turntable. I thought that it might be an issue with the tracking weight so I balanced a penny on the head of the tone arm and this enabled me to play the record through with just a small click in the place where there would ordinarily be a skip - though I understand that this is a really good way to screw up your records if you do it regularly... puzzled
I'd appreciate your suggestions guys, cheers.
Jason36
Jason36's picture
RE: Adjusting tracking weight on Bush MTT1?
Hi PhilD,
I used to own one of these turntables very briefly a few years ago and from what I remember these are pretty much a basic entry level turntable. As far as I am aware there is no way to actually change the tracking weight Im afraid.
__________________
Main System: Laptop > Schiit Modi DAC & Schiit Magni HP Amp > Headphones
Portable: Astell & Kern AK100 DAP / Rockboxed & Modded iPod (128Gb CF Card) / iPad4 / iPhone 4S / ALO Rx Mk3-B Amp / AlgoRhythm Solo DAC
Headphones: Sennheiser HD650 / Beyerdynamic T70p (Modified to Dual Entry) / Heir Audio Tzar 350 / Aurisonics ASG 1.2 / Sennheiser IE6 IEM
Amyl Right Mate
Amyl Right Mate's picture
No you can't.
When I had one about 15 years ago I had a 5p piece permanently attached with Blu-tac.
I have records that always skipped in the same place when played on the MTT1 - Beastie Boys' Hello Nasty for one - that have always played though perfectly on other TTs.
PhilD
PhilD's picture
Amyl Right Mate wrote:
No you can't.
Thanks for the replies guys.
I don't mind attaching a coin if it works and doesn't cause any problems - but isn't it true that doing this damages your vinyl? Or have I been told wrong on this (I'm a bit of a n00b)?
