A little oil - is that ok?
16 replies [Last post]
gbhsi1
gbhsi1's picture
I noticed my turntable making a slight thud noise when spinning around. I have isolated it down to the platter - so is it ok to add a little oil (not cooking or extra virgin of course) to the bearings as I think this is what is causing the noise?
RobinKidderminster
RobinKidderminster's picture
RE: A little oil - is that ok?
Absolutely. Light machine oil or WD40 I would say. On the arm spindle in VERY tiny amounts. Anything mechanical keeping it away from rubber. IMO. I know nuffin'.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
altruistic.lemon
altruistic.lemon's picture
Online
No! Not WD40 whatever you do. Sewing machine oil - or that recommended by the manufacturer - would be fine.
RobinKidderminster
I have used WD40 + cocktail stick but I bow to your greater knowledge. Sorry to give poor advice. Agree with sewing mc oil.
__________________
gbhsi1
gbhsi1's picture
I've bought a little can of 3-in-1 original multi purpose oil drip. It has little spout for precise application. It says you can use it on sewing machines - is this ok?
altruistic.lemon
Online
WD40 is only partly a lubricant; it also contains a heap of additives which clean and free up seized joints. Great for an old and rusty bike chain, but it ceases to act as a lubricant fairly early. I use it for my bike chain, I spray per wek, else it dries.
3 in One should be OK, but the formula also includes some solvents, at least in Oz it does. I've used it, but prefer the straight sewing machine oil. Anyway, if you clean and oil once a year you'll be fine with 3 in One. Don't know your turntable, though, check what the manufacturer says.
By the way, if the noise is coming from the bearing, you need to get onto it quick, so use the 3 in One and change if you find out it isn't the best solution. A dry bearing will quickly kill your turntable.
gbhsi1
gbhsi1's picture
Thanks for the advice - I'm going to do it now :-)
nads
nads's picture
so basically rubbish for a bike chain.
WD40 was developed as a Water Displacer not a lube.
if you want to lube use one.
__________________
Not a HiFi Nut. Just has a pile of Nads.
Excitable Boy
Excitable Boy's picture
After all I've read on here, surely snake oil is best ??
Lost Angeles
Lost Angeles's picture
oil drink to that  beauty, eh
__________________
Orbe SE.
RobinKidderminster
Surely wd40 is ideal to oil a snake? I think tt manufacturers sell tt oil but 3in1 sounds fine.
__________________
altruistic.lemon
Online
In Oz, where many roads are dirt, it's great. Dust sticks less. It is a lubricant, by the way, but you need to use it regularly, as in weekly. Certainly the wrong thing for turntables.
chebby
chebby's picture
Online
You had a Proj-ject Experience 2 the last time I asked.
They would recommend this...
Grease It
'Grease' is apt.  It costs £20...
Clicky
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Alears
Alears's picture
And the result was?
For the future get some proper TT oil (any manufacturer) as even 3 in 1 is a bit on the heavy side.
__________________
Origin Live Aurora Gold+Illustrious Mk2 arm+Zyx R100-02/Stello CDT200+Stello DA220 Dac/Tom Evans Groove Anniversary/Tom Evans Vibe Preamp/Linear A power amp/Acoustic Zen Adagios/ Chord cables
gbhsi1
gbhsi1's picture
Alears wrote:
And the result was?
it's cured the noise and working perfectly. Only applied a few drops.
gbhsi1
gbhsi1's picture
Grease It
Clicky
I will purchase this when I have some extra dosh Smile thanks for link chebby
