54 posts / 0 new
Last post
RobinKidderminster's picture
Last seen: 3 months 3 weeks ago
American Fridge/Freezer assistance please
I will keep this post short by asking if you might please check the rating plate. (environment temperature rating)
My Samsung 5RS is rated as N/ST/T suggesting that it is suitable for environments of 16degC and above. I would expect it to be rated SN allowing an environment down to 10degC.
Since buying the.appliance, for months, I have waited for a clear response from Currys, AO.com & Samsung technical. Few seem to understand the question but eventually Samsung told me (twice) that I should not allow the temperature to fall below 0degC and again a different email telling me that 10degC was the lower limit.
My reading of these ratings are that uk appliances are normally and should be rating SN. So I wonder if my unit is unsuitable for surrounding tempsmuch below 16deg and if so why is mine not rated thus.
I would most appreciate some feedback
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Benedict_Arnold's picture
Last seen: 21 hours 7 min ago
RE: American Fridge/Freezer assistance please
If your surrounding air temperature is zero Celsius, why do you need a fridge (or a deep freeze for that matter) in the first place?
Nothing special Blu-Ray player, Marantz 7010, 7.2.4 with Yamaha NS-IW960, NS-IW660 in-walls & NS-800 in-ceilings, Samsung 6 series 65 inch 4K TV. No stereo worth bragging about.
Marsbardark's picture
Last seen: 2 years 1 month ago
I got 99 problems but a fridge ain't one. Seriously wtf?
Music: TEAC ah300-mk 3, Mordaunt Short. Mezzo 1 Headphones : akg - k 3003i, philips x1, klipsch x10i. Vision: Panasonic tx42 gt50, Panasonic bdt320, denon dvd 1930, Onkyo htx - 22hd 5.1IPad 2, ipodtouch, ipod classic, macbook pro
I would be really grateful to any members willing to check their appliance which would be helpful to me. Uniquely I have to say I am disappointed by unhelpful & dismissive responses.
Thanks in advance.
bigboss's picture
Last seen: 5 days 8 hours ago
Contact them for advice:
http://www.ior.org.uk
bigboss's picture
I found this online:
Depending on the Class rating lowest Class SN 10Deg C and Class N 16 Deg C.
I think you should worry about it only if your refrigerator is kept outside in the garage etc. and exposed to outside temperature.
bigboss's picture
Found another useful link:
http://www.which.co.uk/home-and-garden/home-appliances/guides/best-freezers-for-your-garage/
relocated's picture
Last seen: 1 year 11 months ago
How amusing and so helpful.  Oh and 0C is not a deep freeze
Apple lossless - Netgear Nighthawk - ATV3 - AVI ADM 40.
AVI ADM 9T used in my wife's system
relocated's picture
You and Benedict should start your own mutual appreciation society, you could call it -the waste of space richards society.
Thanks BB. I will email your link.
For brevity I didnt explain details....
My new fridge/freezer is kept in a room where temperatures can drop to 10deg in Winter.. Since purchase a few months ago the temp has been well above. I was surprised to see the the rating N/ST/T but not SN. My concern is that during winter the unit could breakdown or use aditional power or that Samsung could say that the unit is not installed properly and avoid warranty claims. I recon uk units should be SN rated.
I have been contacting Samsung repeatidly, responses taking weeks. I have had 2 emails stating that the unit should.not fall below 0 (which is nonesense) and 1 email saying that down to 10deg is fine - in which case why does it not have a SN rating?
I would be prepared to get the unit replaced as 'not fit for purpose' unless Samsung can explain why their unit does not have the SN rating. Responses from retailers (and Samsung customer services) has shown a total ignorance in this matter.
I will drop into Currys and check out their appliances as well as emailing as suggested.
Hopefully this better explains my request for others.
Thanks relocated - appreciate your support.
When you spend £1200 and spend months looking for answers its a bit frustrating to be dismissed.with stupid comments.  :cheers:
Paul.'s picture
Last seen: 2 weeks 1 day ago
If you have it in writing, it does not matter if the answer is right or wrong.  Print the email and keep it with your warrenty documents, job done Smile
Agreed Paul but I would rather fight the fight now rather than in a few years time. And is my appliance going to use lots more electric during colder months?
Paul.'s picture
Im not sure...  some machines only have one temperature control unit in the fridge and not the freezer. If it gets too cold outside, the fridge decides its doing its job properly and shuts down the motor. The freezer will then start to heat up to above -18. I would be inclined to keep a separate thermometer in your freezer compartment to be safe.
The other factor is modern CFC free refrigerants, they are a bit rubbish compared to the old gases they used to use. Thats why you always get people saying "my old Electrolux has been in the arctic for 35 years and its fine..."
Is it an RSG5 that you have?  If you scroll down to page 81, it is listed as SN-T.
http://www.appliancecity.co.uk/documents/Samsung-brochure-2012.pdf
Thanks Paul. Agreed. My concern is that despite all documentation and advice I wonder why the registration/specification plate inside my appliance says N/ST/T but excludes SN? Which is why I asked other Samsung users if their units were similarly labelled.
Paranoa is giving way to frustration. Guess more pills needed.
Broner's picture
The exact details of the classification are written in a standard: http://www.techstreet.com/products/1863922
The standard costs a lot of money, but you can access it for free if you go the BSI office. Anyway, I assume that the following website is correct: http://www.the-appliances.com/articles-home-appliances.asp?id=15 , meaning that your refridgerator is indeed suitable for temperatures between 16 and 43°C. It's clear you've got yourself a fridge that's suitable for a normal-warm climate.
N = normal
ST = subtropic
T = tropic
You could try and ask whether it's really that much of a problem if the outside temperature goes down to 10°C and what the risks are, but the specifications are pretty clear.
Pages
Log in to post comments
