Laptop with HDMI output
5 replies [Last post]
rendu
rendu's picture
Hello, do you think this will be critical in future?  If yes, why?  I am between 2 laptops one with and one without.  The one with is more expensive and I like it less so the only reason to get it would be the HDMI.    Thanks!
__________________
Yamaha A2010, Dali Ikon 1, Dali suite C0.7, Wharfedale DFS and Wharfedale SW150.  IPOD 80 GB with Pure digital I-20. PS3 slim. Harmony 600, Optoma HD65 proyector.
Sonic impact T-amp with Whafedale 9SR.
Paul.
Paul.'s picture
Online
RE: Laptop with HDMI output
I wouldnt worry about it too much, DVI, VGA, and I think Thunderbolt can all be converted to HDMI with the right cable.  You may need to run a seperate audio cable however.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
AnotherJoe
AnotherJoe's picture
Online
vga is not easily converted to HDMI (analog to digital).
HDMI gives you more & easier connection options than dvi or displayport. But it depends on what output you plan on connecting to.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
hammill
hammill's picture
Online
I bought an Acer with a blu-ray and HDMI to enable us to watch blu-rays when we are on holiday. I have found it money well spent.
snivilisationism
snivilisationism's picture
Our 2 laptops have it. And one is a cheap 13.6 inch Lenovo. Definitely worth it Smile
__________________
"In the practice of tolerance, one's enemy is the best teacher." - Dalai Lama
MajorFubar
MajorFubar's picture
That's a difficult question to answer without knowing your requirements. If you only ever plan to use it as a laptop using its own screen then it doesn't matter what sockets it's got. If you intend to use it to play/stream HD video to your TV, then HDMI seems currently to be the most universal interface for that task.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
