Bristol show 2012
Hi ppl any news and dates on Bristol Hifi/home cinema show happening??
Friday, February 24th to Sunday, February 26th 2012.
Yes, we'll be there, but no sign of a THX exhibit as such.
Looks like there will be no Panasonic or Samsung either. That would be two years on the trot. I went to Manchester in 2010 and all the main tv manufacturers were there. Any reason for the Bristol show becoming less about the vision??
The timing might not be right for them, if they're not ready to show their new products then there's not much point turning up with last year's models that will be replaced soon. The Manchester show is later in the year. The focus of the Bristol show is typically more on the audio side anyway imo.
Indeed. For example, Panasonic will only fully reveal its 2012 UK line-up (to retailers and press) earlier in the same February week the Bristol show falls; first models won't hit shops until end Feb/early March at very earliest.
Yes, Bristol's a bit too early for the big TV companies to exhibit their new UK ranges, but don't forget there'll be lots of other exciting product launches from some of the smaller companies, as you can read in my blog.
Ooh, new primare kit, exciting!
I have booked my flights for the Bristol Show. I am flying down from Glasgow. Will 5 hours be enough time?
I should hope so, you could fly to Russia in that time!
Oh you mean for the show? Is that 5 hours between flights or do you mean 5 hours actually at the show? If it's the former then realistically, probably not, Bristol Airport is a fair way out from Bristol centre, probably 45 minutes by cab (maybe an hour), so that's an hour and a half to two hours gone, then you've got to get there in time, check in, blah blah, probably another 30 minutes either end, so you're down to 2 and half hours in the show, it's a big show and it's spread over lots of floors, if you sit in on any demos they're usually a good twenty minutes, so three of them and you only have an hour and a half for the rest of the show. So no, probably not.
I should have said I will have five hours at the show. I arrive at Bristol Airport at 10.30am and fly home at 19.30pm. I was worried that the show will be very busy and I would need wait for demos in rooms because they only hold so many people. eg going to Alton Towers all day but only getting on 3 rides lol
Hello,
If I buy 2 twoday adult tickets with audiot UK onlineshop for the hifishow can we use them on friday and sunday?
With regards,
Bart
Belgium
Link here
http://www.bristolshow.co.uk/
