Kit racks..
2 replies [Last post]
TimBisley
TimBisley's picture
I've been adding things to my kitrack on and off for ages without any thought to the mess of wires gathering behind, but things came to a head when I bought a new set of surround speakers and had to take everything out and start again.
I went to Screwfix and bought a load of cable ties, and sent away for an ethernet switch and some short ethernet cables, then rewired everything keeping it all neat (I decided to go for a wired connection to my networked equipment because of stability issues on my WiFi).
I guess this isn't really a "Top Tip", but it sure made me feel better knowing there wasn't a load of spaghetti behind my stuff. My wife approves, too!! rolling on the floor laughing
One thing I did find is that moving my speaker cables away from the power ones as you have recommended in the past did make a difference to the sound. I don't know if this is just wishful thinking from me or if something really is happening, though.. any thoughts?
__________________
"You Lando…"
TimBisley
TimBisley's picture
RE: Kit racks..
Don't all reply at once! Tongue
__________________
"You Lando…"
Andrew Everard
Andrew Everard's picture
RE: Kit racks..
In general it's advisable not to have signal cables, be they interconnects or speaker cables, running parallel with power leads, and certainly not cable-tied together.
If you're going to take this approach, best to bundle the power cables together and tie them in one 'loom', interconnects in another, and speaker cables in a third.
If possible, where power cables and signal cables meet, they should cross at right angles (if you're going to get all annual about these things!)
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
