Wireless N house coverage?
I've just got my first Wireless N dual band router.
I have my iPhone on the 5ghz band at home, and am surprised to find that the wireless coverage is not significantly better around the house than with my old Dlink wireless G unit from 8 years ago.
I get 1 of 3 bars on the wireless upstairs, and at the back of the house, and apps like TuneIn have to buffer a lot when streaming radio.
It's got me a bit worried because I was hoping to develop Airplay units in various spots around the house, but I'm now not sure my wireless network could deliver lossless in this way.
It's not a palace, I live in a Victorian terrace, so I'm a little surprised the wireless isn't a little stronger with the new router.
Would people say this is typical, or are there things I should look at?
Do people find Wireless N is enough to deliver Airplay around the house?
Thanks.
- Login to post comments
If your main concern is range then you should be using 2.4Ghz not 5Ghz.
The higher the frequency of a wireless signal the shorter the range.
5Ghz is only worthwhile if you have a lot of interference.
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
