4 posts / 0 new
Last post
alializadeh's picture
Last seen: 3 years 3 months ago
soundcard or dac
hi
a simple question, i'm planning to build a mid range/hi end htpc wit mini itx motherboard and z87 socket.
and  i want to connect my htpc to my amp, wich is better? pci exprex soundcard? or a dac like music streamer pro?
thank you
joelw's picture
Last seen: 9 months 2 weeks ago
RE: soundcard or dac
Usually an external DAC as far as I know, should provide much better processing of music.
abacus's picture
Last seen: 1 week 13 hours ago
A quality pro sound card will give you a really top notch sound, (Studio quality) however they are expensive and quite large, and therefore as you are building a small format PC I would go for an external DAC.
NOTE: A lot of pro DACs use a fire wire interface instead of USB so if you decide to go for one of these you will need to add in a fire wire card. (Fortunately they are very small in size)
Hope this helps
Bill
AnotherJoe's picture
Last seen: 1 year 10 months ago
Assuming your music is in lossless - eg FLAC then any 24bit soundcard with an optical out will give the best possible quality.
Something like an ASUS Xonar DS for £35 will be all you need.
If you have a Radeon graphics card that supports HD sound then you could also use that for the sound via either DVI(with the dongle that came with it), or HDMI.
Log in to post comments
