14 posts / 0 new
Last post
floyd droid's picture
Last seen: 2 years 6 months ago
Pulling my hair out !!.
Ok I need a pooter Geek and talk to me like I'm an alien as I'm rubbish when it comes to going into the scary bits on my computer.
Right here we go. A couple of days ago I opened my tab for another forum I use and got a picture on screen with the forums name on it , not what I expected , strange !!. Then,after a couple of close tab / open tab attempts the home page returned to normal , all good so I thought.
Since then the tab will open no problems , with the correct home page but when I reload I get 'oops google cant find blah blah blah'.
I have gone through Chromes suggestions to stop this , clear cache etc etc , to no avail. I have tried an incognito window ,nope. Tried firefox ,nope.
No problems with whathifi or any other forums I have tabbed.
Ran a thorough scan last night which took yonks but came up with nowt.
Any ideas whats going on here fellas.
Ta floyd.
The_Lhc's picture
Last seen: 2 months 2 days ago
RE: Pulling my hair out !!.
What's the address of the website in question, it may not be a problem at your end? Getting a "picture on screen with the forum's name on it" doesn't sound like anything Chrome would do (I've certainly never seen that on mine).
Yeah as I say really strange . It was a picture of a smiling bird with hifiwigwam on it !!.
www.hifiwigwam.com.
It loaded a few minutes ago , reloaded as its always busy with new stuff , Ooops yet again .
michael hoy's picture
Last seen: 11 months 1 week ago
www.hifiwigwam.com.
Hi can you re check your link, the one you posted has a dot after the name - can't find the server at www.hifiwigwam.com. .
try this link - http://www.hifiwigwam.com
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
Nope !. Got oops yet again. This is really odd as it loaded from my tab a couple of mins ago did a reload and oops yet again. Did a search on google for the wam ,clicked that , it loaded up clicked reload ,oops !.
Sometimes it will reload two or three times then I get that flippin oops. I've just read on tinterweb I could have a corrupted host thingy in my computer ,out of my depth here I'm afraid.
Can you connect to other sites OK or is it just this one.
Yip as I said earlier , no probs with pinkfish/vinylengine etc etc just the wam.
The_Lhc's picture
michael hoy wrote:
www.hifiwigwam.com.
Actually there's no issue with a . (dot) at the end of a web address, . (dot) is in fact the highest level domain, com and the like are sub-domains of . (dot). It (dot) should be included on EVERY web address but browsers simply assume the . (dot) to avoid people having to add it.
The problem with link posted is in fact because there's a space included at the end of the link, take that off but leave the . (dot) and it works fine.
The_Lhc's picture
I think it's just that website, although I can't reproduce what you're seeing. I'm not trying very hard though to be honest.
Thanks for having a look mate. It loaded up around an hr ago so I left it be. Just reloaded ,lol.
If it happens again I'm getting a geek in. A bit more web trawling is leaning towards an irritating little virus host file which some smart alec thought would be fun to do.
The_Lhc wrote:
michael hoy wrote:
www.hifiwigwam.com.
The link posted by the OP does not work if you click on it, remove the dot and it works.
I know it should work, just trying to eliminate the fault with the link and keep it simple.
I cannot replicate the OP's issue either.
The_Lhc's picture
I didn't remove the dot though, I just removed the space (the %20 on the end to be exact), the dot remained and it worked fine. It may possibly be browser dependant, although it shouldn't be.
My link just worked for me ?. Anyhoo its kiss of death time . its reloaded without a hitch all afternoon.
Prolly until now ,ha ha .
Ah that 20% was my trigger finger , didnt notice that tbth. Anyhoo it worked as it stands from my end.
Log in to post comments
