My set-up fails this audio test - does yours?
My US$1,500 pc and same-priced external amp/speakers failed this test. I would imagine most speakers would - what do you guys think?
From
http://people.xiph.org/~xiphmont/demo/neil-young.html
If you're curious about the performance of your own system, the following samples contain a 30kHz and a 33kHz tone in a 24/96 WAV file, a longer version in a FLAC, some tri-tone warbles, and a normal song clip shifted up by 24kHz so that it's entirely in the ultrasonic range from 24kHz to 46kHz:
Intermod Tests:
- 30kHz tone + 33kHz tone (24 bit / 96kHz) [5 second WAV] [30 second FLAC]
- 26kHz - 48kHz warbling tones (24 bit / 96kHz) [10 second WAV]
- 26kHz - 96kHz warbling tones (24 bit / 192kHz) [10 second WAV]
- Song clip shifted up by 24kHz (24 bit / 96kHz WAV) [10 second WAV] (original version of above clip) (16 bit / 44.1kHz WAV)
Assuming your system is actually capable of full 96kHz playback [6], the above files should be completely silent with no audible noises, tones, whistles, clicks, or other sounds. If you hear anything, your system has a nonlinearity causing audible intermodulation of the ultrasonics.
Dunno, my system has no physical connection to a computer so I won't be trying this.
I wonder if anyone will ditch their hi-fi due to it failing these tests. I hope so
Hmm interesting.
Only tested it so far in my little bedroom-come-studio with my iMac connected to my Alesis active studio monitors.
(Yes I remembed to set the sample-rate in Audio Midi Setup to 96kHz)
Resounding pass.
Not sure if my domestic HiFi will pass so well...
Brilliant article. I could hear a click at the start and end of each sample, is that a pass or fail?
Interesting read, got to say some of it went over my head but i got what it was getting at.
My Cheap Cheerful Setup
LG 50PA650T , Sky HD , Sony BDPS185B , Xbox 360 , Sound Organisation AV Rack
Yamaha MCR-555 , Shuffle , Beyerdynamic DTX 71iE
