How do I fix my laptop keyboard?
4 replies [Last post]
smithJames
smithJames's picture
Almost all my keys on my Toshiba Keyboard are pressing the key above it or the left or right of it. For exmaple, when I press Q, it turns on Caps lock and puts a capital Q and when I press it again it puts a small q. Another exmaple is when I press m, mj is typed. It does this for almost all the keys except backspace, what should I do? I am using a Toshiba model satelite A355 if that helps somehow.
fr0g
fr0g's picture
RE: How do I fix my laptop keyboard?
Sounds like a knackered keyboard and one drawback of a laptop. You should be  able to order a new one though. Try ebay for cheap replacements or the Toshiba site for a genuine one with warranty.
Some laptops are easier than others to change keyboards on, so good luck. (I have changed kb on my last 3 laptops through being a clumsy EDITED)
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
toyota man
toyota man's picture
Online
 you could get a usb key pad  job done:) Smile
__________________
bigboss
bigboss's picture
Online
A couple of my friends had the exact same problem with their Toshiba laptops (perhaps a known issue?). I'll ask them what they did & report back. One is on his honeymoon abroad & won't be back until next month. How old is your laptop?
__________________
Alantiggger
Alantiggger's picture
You could try changing keyboard layout to US then change it back and see if that helps  ?
or perhaps ... if you type an 'm' and you get an 'o' ... see here :
http://www.computeractive.co.uk/ca/pc-help/2029314/typing-wrong-letters
__________________
Lounge :  Samsung PS51E6500, Sony BDP S790, Virgin media XL, Onkyo  TX-SR508,
Tannoy Arena 5.1 with stands.(http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speakers/tannoy-arena-96472/review)
Bed : Panasonic PX70 and a Sony BDP-370 Blu ray Player.
So far  :)
