6 posts / 0 new
Last post
JamesMellor's picture
Last seen: 1 day 5 hours ago
Help HDD failing on Mac book pro
Hoping some one can help me , over the last few days my MacBook has been crashing while ripping cd's , Disk utility recovered errors on the HDD but it's still showing up Red and warning the disk is about to fail , copying all my music and word / excel doc's to a usb HDD as I type.
I figure I can go buy another 512 gig HDD , or larger ? and fit it but what I'm not sure about is how I will reinstall osx ( 10.9.2 ) .
If I buy a usb drive big enuff to do a time machine back up will it restore that to a new HDD ? or can I create a reboot disk that will reinstall osx .
I query the time machine because in disk utility it says only restore to the same machine
Thanks in advance
James
emperor's new clothes's picture
Last seen: 2 weeks 3 days ago
RE: Help HDD failing on Mac book pro
Could back up to iCloud and tick box "back to my Mac" Good luck.
SBT->Marantz SA14S1se->PM14S1se-> Dali Opticon 6.
Sky HD,Fire stick,Marantz UD7007->Denon X6200W->biamp Dali Ikon 6MK2, Vokal2, B&W601S3 rears. Pioneer Kuro KRP600.
IMac->Arcam rPac-> Senheisser HD558.
John Duncan's picture
Last seen: 2 months 1 week ago
I would recommend not using Time machine, because it won't create a bootable backup.  Use something like CarbonCopyCloner to create a bootable backup, boot from it and copy it over to the new HD.
EDIT - Chebby uses SuperDuper! iirc. Also creates bootable backups.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
chebby's picture
Last seen: 2 hours 15 min ago
Yep and my weekly (bootable) backup paid off handsomely the only time I ever had to use it 'in anger'.
Our iMac's HDD failed (3 weeks before it's 3 year Apple Care was due to expire) and Apple had an approved repairer courier it away, replace the HDD (with a larger one which was nice), then courier it back. All free of charge and it took 5 days in total.
Once it was back from the repairer, I plugged in the external backup drive and booted from it then 'backed up' to the new internal HDD. It didn't miss a beat.
I still back up all three of our systems to external HDs regularly (still using SuperDuper! for the iMac). I can't understand why some people don't.  It takes no effort.
I also have all of my photos (and music and some other important stuff) duplicated on two different systems (and their backups obviously).
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
Thanks guys , I'll try that once I figure out why my internet went down  :help:
not having the best of days
James
Backed everything up using superduber , had to buy it to do the smartback up as the old HDD kept crashing it , had to delete some files that wouldn't copy , fitted the new HDD and restored it .
Everything appears fine and running faster than before , no spinning globe I used to get alot over the last few months .
So Thanks for all the help guys .
One thing , while looking on the internet found out that 2011 macs onwards will download xos over the wifi if rebooted holding down the R key and will then restore from a time machine back up , I'd already bought the new ext HDD and super so I didnt try it.
James
Log in to post comments
