15 posts / 0 new
Last post
Benedict_Arnold's picture
Last seen: 1 day 18 hours ago
Dead PC - Ideas?
Nothing special Blu-Ray player, Marantz 7010, 7.2.4 with Yamaha NS-IW960, NS-IW660 in-walls & NS-800 in-ceilings, Samsung 6 series 65 inch 4K TV. No stereo worth bragging about.
simonlewis's picture
Last seen: 4 days 20 hours ago
RE: Dead PC - Ideas?
Could be the psu.
My post came up blank again.
I've tried two different cases, so I can rule out the PSU.  It's either the MB, CPU or RAM (obviously).
I'm getting nothing, not even a BIOS splash screen, so prime suspect is the MB.
Thoughts?
Alantiggger's picture
Last seen: 1 week 4 days ago
Alantiggger
Great link here  ((with great links from here too)
http://pcsupport.about.com/od/findbysymptom/tp/computer-wont-turn-on.htm
Alantiggger
Duff DIMM was the problem.  The PC is working fine with just one 4GB DDR2 DIMM right now.  Problem is DDR2 RAM is now so pricey that it's cheaper to upgrade the MB and replace all 8GB (the working 4 and the duff 4) of DDR2 with DDR3 than it is to buy a single 4GB DDR2 800 DIMM.  Grrr...
Indeed  Smile
Well the computer will work real well with the newer memory   Smile   Good  then     :bounce:
Alantiggger
Alantiggger wrote:
Indeed  Smile
DDR2 and DDR3 aren't interchangeable - grrr
Yeah, I misread... anyway get a new mobo and the newer, cheaper memory then as it will be a lot better.
I bought this mobo about a year or so ago and it is a pretty decent one for the money : http://www.techpowerup.com/reviews/ASUS/P8P67%20PRO/
It might be worth a look at Benedict_Arnold and as you say the memory IS pretty cheap. add a decent cpu and you are good to go    Smile
Alantiggger
I forgot to add that I bought the Intel Sandybridge i5-2500K Unlocked Core i5 Quad-Core Processor  CPU  (3.30GHz, 6MB Cache, Socket 1155)
There is also the cheaper i3 2120 Sandybridge Dual Core 3.30GHz Processor CPU  around  £90.00 or so and cheaper still the Intel Pentium G860 3.0GHz Dual Core CPU which can be bought for around the £50.00 mark.
Alantiggger
Yeah, but this was the left-overs from the left-overs PC.  Not going to spend any more moolah on it unless someone else (i.e. 'er indoors whose office it is intended for) coughs up.
In April I upgraded my primary PC to an i7-3930K 3.2 GHz hex-core with 32 gigs of RAM and a shedload of RAID'd SATA-3 storage.  The leftovers from the upgrade were added to a cheap new motherboard to build an Q9650 3 GHz quad-core media PC with 2 terabytes of RAID'd SATA-1 hard disks and 8 gigs of RAM, and the left-overs from that got used to build the PC in question.
Ahh  !
Well, keep remembering to tell your other half as to HOW GREAT it would be to upgrade   Smile
As to WHY it will all be for    'her'  etc    Smile
Alantiggger
AnotherJoe's picture
Last seen: 1 year 11 months ago
Buy a second hand 4gb ddr2 stick off ebay for around $30
fr0g's picture
Last seen: 4 months 3 weeks ago
tbh 4GB is perfectly adequate for a 3rd PC.
I can remember when 4 MEGAbytes was considered a lot of RAM....
Pass me pipe'n'slippers would you?
Log in to post comments
