7 posts / 0 new
Last post
bigboss's picture
Last seen: 1 week 14 hours ago
256GB SSD capacity - how much should it actually be?
My Sony Vaio Pro 13 arrived today. The SSD is supposed to be 256GB, but it's only showing 212GB. As far as I'm aware, the true capacity of 256GB should be 238GB. Where's the missing 26GB?  :?
bigboss's picture
RE: 256GB SSD capacity - how much should it actually be?
Found it......used up by the recovery partition.
MajorFubar's picture
Last seen: 4 days 11 hours ago
Crikey the hard-drive on my first Windows 95 PC was only 4GB in total and for recovery it had a single CD. Now they need 26GB for a recovery-partition.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
AnotherJoe's picture
Last seen: 1 year 11 months ago
As long as you have the Windows CDs you might want to delete the recovery partition and reformat the drive into a single partition.
Benedict_Arnold's picture
Last seen: 3 days 2 hours ago
Could be a bad move on a laptop IMHO unless you never take it anywhere.  Just imagine you turn up at someone's offices to work and how to scrounge a copy of Windows to connect to their network or printer or,,,,
Just saying...
Nothing special Blu-Ray player, Marantz 7010, 7.2.4 with Yamaha NS-IW960, NS-IW660 in-walls & NS-800 in-ceilings, Samsung 6 series 65 inch 4K TV. No stereo worth bragging about.
professorhat's picture
Last seen: 2 months 1 day ago
Just saying...
I think WIndows has changed a lot since you last used it. You no longer need to carry around the CD in case you need a new printer driver etc.
The owls are not what they seem...
expat_mike's picture
Last seen: 3 weeks 5 days ago
I think that you can also set up laptops and pcs to boot first from the hard drive, but if that fails then to boot from the USB port.
So put all your emergency files (including backup copy of windows) on a memory stick, and always carry it in your pocket (or on your keyring).
Hopefully you never need it, but it could save your bacon one day.
Log in to post comments
