Where can I buy terminal links for my TDL 0.75M speakers?
3 replies [Last post]
ajw318
ajw318's picture
I've got a problem for you. On my old amplifier, a Technics SUA-900, I had my speakers bi-wired as the amplifier was set up for bi-wiring. I've now bought a Brennan JB7 and am very pleased with the sound it produces! There is however no option for bi-wiring and I've lost the terminal links which convert my speakers for single-wire use. I've got over this by bareing the first 10cm of speaker cable and connecting it to both terminals, which works ok but is not a tidy option. So far I have contacted Sevenoaks Hi-Fi, but have received no response
robjcooper
robjcooper's picture
RE: Where can I buy terminal links for my TDL 0.75M speakers?
Try these people:
http://www.tdl-loudspeakers.co.uk
Rob
Big Chris
Big Chris's picture
Using speaker cable links is often an improvement in sound over the factory supplied links. I say stick with the speaker cable links and if you're worried about untidiness, spend your money on some screw-on banana plugs instead.
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
ajw318
ajw318's picture
Thank-you for your reply! It's good to know I've done the right thing, accidently! I'll leave them as they are,
Andy
