plugs and fuses
2 replies [Last post]
TheLastManWithB...
TheLastManWithBetamax's picture
Does anyone know what happens if you say use a 13 amp fuse when you ought to be using a 10 amp one?
nads
nads's picture
Re: plugs and fuses
Nothing.
if everything works fine.
but if you have a fault it will not blow at the level it should and could cause damage to your electrical item(Drunk.
__________________
Not a HiFi Nut. Just has a pile of Nads.
Andrew Everard
Andrew Everard's picture
Online
Re: plugs and fuses
Don't ever be tempted to do this.
The fuse rating is there for a reason, which is to stop major problems should a fault develop in whatever the fuse is meant to protect.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
