Need mattress advice
49 replies [Last post]
simonlewis's picture
I'm thinking about buying a mattress this year as mine is getting on a bit, i would like a metal free foam mattress with memory foam topper, ive seen on the telly a dormeo memory  foam mattress 12+2 greatly reduced in price but i'm not sure if it will be any good or not, i've also looked at bensons for beds & i've quite fancied one of the sensaform mattresses, are their any others i should consider ???
Appreciate any help, but i want one that is metal free.
__________________
formerly known as slewis ---
simon's system
CnoEvil's picture
RE: Need mattress advice
Would you consider a full memory foam mattress (with a cover that prevents sweatiness)?
I use one and can give you the details if you're interested.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
No not really because it would be expensive, i was thinking £500 tops for a kingsize, i would really like an octosprung but that is way out of budget.
__________________
simon's system
gel
gel's picture
I got a new double bed and mattress from Bensons For Beds just before Xmas:
http://www.bensonsforbeds.co.uk/Bed-Frames/Leather-and-Upholstered-Bed-F...
 That was the bed.
I got a pocket sprung mattress, can't find which one.  Pretty happy to be honest.
__________________
Main AV Setup: Panasonic 50VT65 TV (THX calibrated), Pioneer Bdp-lx71, Pioneer Vsx-lx70, B&W FPM Series, B&W PV1, Optimum AV300 AV Stand, QED Silver Anniversary XT Speaker Cable & Chord Silver Plus HDMI Cables. Gadgets: iPad 4 & iPhone 4S.
Thanks gel.
__________________
simon's system
bigboss's picture
Online
Personally, I didn't like memory foam mattress at all. Too uncomfortable, especially when turning in sleep and sweat inducing.
I would recommend this:
http://www.johnlewis.com/john-lewis-pocket-ortho-1400-mattress-kingsize/...
__________________
bigboss's picture
Online
__________________
Thanks bb, i will consider, what does pocket sprung mean (springs in pockets) i really wanted one without metal, a foam one with memory foam top.
__________________
simon's system
CnoEvil's picture
The crowd I use has a 20% sale on atm, which brings the 18" version close to budget (£519 down from £649): http://www.sleepform.co.uk/products/memory_foam_mattresses/tempcontrol_m...
The Outlast cover prevents sweating.....for us anyway: http://www.sleepform.co.uk/sleepform/outlast.html
__________________
gel
gel's picture
bigboss wrote:
Personally, I didn't like memory foam mattress at all. Too uncomfortable, especially when turning in sleep and sweat inducing. I would recommend this: http://www.johnlewis.com/john-lewis-pocket-ortho-1400-mattress-kingsize/p231510947
Same.  Smile
__________________
BenLaw's picture
Pocket sprung here too. As long as it's not too cheap, you won't feel the metal, it doesn't need turning etc.
__________________
HiFi   /   A/V   /   Bedroom
bigboss's picture
Online
Check this guide:
http://www.johnlewis.com/buying-guides/mattresses-buying-guide
And this video:
http://www.johnlewis.com/inspiration-and-advice/home-garden/archive/john...
As the advice always goes on here: definitely demo (try the mattress in shop by lying on it) before purchase! Smile
__________________
gel
gel's picture
I think this might be mine:
http://www.bensonsforbeds.co.uk/Mattresses/Pocket-Sprung-Mattresses/Doub...
It supports your back well, and is really comfortable.
__________________
gel
gel's picture
No sorry that is not it but similar, I think it was £350 mine.  Medium comfort I think.
__________________
bigboss's picture
Online
Some of the very best mattresses are pocket sprung:
http://www.johnlewis.com/vi-spring-stowe-mattress-kingsize/p231352342
http://www.vispring.co.uk/
If I remember correctly, the Queen uses this brand.
__________________
__________________
simon's system
