Need Advice About ICE
23 replies [Last post]
simonlewis's picture
My birthday is coming up soon & i've decided that i want a new stereo for my car, i was looking at the internet & came accross this JVC i went to the shop on friday but i was told that he didn't have any in stock but showed me this discounted Clarion which i am now quite interested in & will probably buy.
I am not really interested in the radio, so i'm not prepared to pay more for DAB, but what i want is ipod connectivity & a built in satnav, does anyone have any oppinions or advice.
Here is a photo of my dashboard.
001
__________________
formerly known as slewis ---
simon's system
shooter's picture
RE: Need Advice About ICE
simonlewis wrote:
...does anyone have any oppinions or advice
Go to Halfords  excellent!
Happy birthday  beauty, eh
MajorFubar's picture
How about hunting down a forum for owners of your make/model of car and see what the recommendations are.  Other people's success-stories/disaster-stories might steer you in the right direction, and more importantly away from the wrong one.  No offence but just about the last place I'd ask for advice is Halfords, if the staff at my local branch are typical.  Don't get me wrong they always come across as nice lads, but really I wouldn't trust their opinion on anything remotely technical.
__________________
Main system: Mac Mini 2011 • HRT II+ DAC • Lacie 3TB Cloudbox NAS • Marantz PM66 KI • EB Acoustics EB2
In storage: Thorens TD160 (no cart) • Cyrus 2 + PSX • Cyrus tuner • Technics SL-P777 • Marantz CD63KIS • Nakamichi DR-1
I did go to halfords & i wasn't impressed by their service,  i am now going to deal with car audio center :)  they have a better selection, i have been looking at both models tonight & i now think i may go for the JVC because it has face off but it doesn't have a rear usb port which the clarion does so you can route the wire into your glove box for your ipod, so i have to decide,
No face off & rear usb port, or
Face off & no rear usb port.
Thanks for the birthday wish btw but it's next friday (14th)
__________________
simon's system
Binman's picture
Can't give you advice on either of these specific models, but I'd recommend a good quality ipod cable if you go for the rear mount options.  I've bought a few cheap ones from ebay and they all disintegrate after a month or two - you dont want to remove the headunit to replace the cable.
Also -  what size Ipod have you got?  If its a small capacity one, you could just use the SD card slot as they are pretty cheap these days (but try it, as some headunits have limits on number of tracks, and the navigation to music can be a little clunky)
Finally - most important - take your Ipod to a shop and test out how good the interface is with the headunit.  I have a single din Pioneer and the Ipod interface is pretty good.  Some I tried were terrible - very slow and clunky.
Thanks for the info binman, i have a 4gb ipod nano 2nd gen i think, i don't use it much, how would i find out if it can play music from an sd card & what size sd card, -that sounds quite interesting btw.
__________________
simon's system
Just read the small print WMA on sd cards thanks one again.Smile
__________________
simon's system
The_Lhc's picture
Other Brands are available, don't limit yourself to those two just because they're the only ones you've looked at. You might find one with the combination of face-off/rear USB that you're looking for.
I did look at other brands last night including kenwood but that is £100 more than the jvc & clarion & doesn't have face off, so it just left me evan more confused, i've also looked at alpine & sony.
__________________
simon's system
The_Lhc's picture
Pioneer's a good shout, depends on your budget really. I can't tell what car that is from the picture, but you might find with a new stereo you'll quickly discover what the limits of the speakers are.
The car is a skoda fabia (i purchased it for economical reasons) i'm really looking for a double din unit with ipod or usb control & built in satnav, both the clarion & jvc are around £500, i did look at the pioneer last night & decided it was too expensive.
__________________
simon's system
I've had another look around & i am now tempted by this kenwood which seems to tick all the boxes, i can get it for less than £600 on amazon i'm not sure about the two star review though.
Has anybody got any comments or views about this model.
__________________
simon's system
Ordered the kenwood from amazon, see post above. ^^^
__________________
simon's system
6th.replicant's picture
6th.replicant wrote:
Would welcome any advice good or bad, not 100% sure i've ordered the right car stereo but it seemed to tick all the boxes.
__________________
simon's system
nads's picture
you may need to order a new facia part.
__________________
Not a HiFi Nut. Just has a pile of Nads.
