iMac and Netgear issue
For some odd reason when the Mac goes to sleep i loose wireless connection and have to click on the network to get connected but i dont need to type the password even though its locked.
Any ideas, this has only started recently
I sometimes get this with my MacBook Pro - only 2 or 3 times a year though. A reboot usually sorts it.
Other things to look at are the wi fi prefs and ensure your wi fi network is at the top of the list and delete any others which maybe on there that you don't need - it could be trying to pick up your neighbour's for example.
And, as with all things Mac, repair disc permissions in the Disc Utility.
Thanks roger. Yep the network is at the top and if i go into network preferences i can delete the neighbours but when i click on the wifi icon at the top of the screen it still shows the deleted?
Havent done a reboot, is that the same as a restart? Done the permissions thing only last week.
Yes - restart!
In the end this worked:
System Preferences > Network > Turn WiFi Off > Click Advanced and delete Preferred Network > Then reconnect to network
- Login to post comments
Synology DS212J-> AppleTV-> rDAC->Naim Nait5i. Naim CD5i. Dynaudio Audience 52SE
Sony BDPS370 / YouView ->Yamaha RXV1065-> Pana TH42PX80B plasma.
