Format Posting Primer
There have been one or two of these. This one goes a step further than most.
Dividing up text
Use <p> at the end of a line to create a new paragraph
Use <br> at the end of a line to start a new line
Use <hr> to place a line across the page e.g.
Emphasising Text
Use <b> and </b> either side of your text to make it bold
Use <i> and </i> either side of your text to make it italic
Use <strike> and </strike> either side of your text to strike it out
Use <u> and </u> either side of your text to underline it
Use <em> and </em> either side of your text to emphasise it
Use <sup> and </sup> either side of your text to make it superscript
Use <sub> and </sub> either side of your text to make it subscript
Use <code> and </code> either side of your text to change the font
Use between text to force a space
Quoting
Creating your own block quote
Use <blockquote> and </blockquote> either side of your text eg
Here's my quote...i don't know what to say but I'll have tothink of something to be able to demonstrate what the block quote tags can do. Effectively they place space to the left and right of the inserted text.
Lists
Ordered and unordered lists do not seem to work. Pity.
Linking
To link to another page you will need the URL of that page. This is available from the address box of your browser. Once you have this address use the following to put the link in your post
<a href="Your URL here, keeping the quotes">The text to display here</a>
For example, if you put the following in your post
<a href="http://whathifi.co.uk/forums/">This links to the forums</a>
The following will be displayed, allowing the user to follow the link to the forums page
Emoticons
Use the following to place in an emoticon image.
<img src="URL to image"/>
| Emoticon Type | URL | Image |
| Smile | http://community.whathifi.com/emoticons/emotion-1.gif | |
| Grin | http://community.whathifi.com/emoticons/emotion-2.gif | |
| Surprised? | http://community.whathifi.com/emoticons/emotion-3.gif | |
| Eager? | http://community.whathifi.com/emoticons/emotion-4.gif | |
| Wink | http://community.whathifi.com/emoticons/emotion-5.gif | |
| Sad | http://community.whathifi.com/emoticons/emotion-6.gif | |
| Confused? | http://community.whathifi.com/emoticons/emotion-7.gif | |
| Bemused? | http://community.whathifi.com/emoticons/emotion-8.gif | |
| In a sweat | http://community.whathifi.com/emoticons/emotion-9.gif | |
| Embarassed | http://community.whathifi.com/emoticons/emotion-10.gif |
So placing this in your post
<img src="http://community.whathifi.com/emoticons/emotion-10.gif"/>
will display this in your post
Images
Use the following to place in an image in your post.
You can only post images which are available on line.
Find the image you want to display. Right click the image and select properties. Copy the URL and use it to define the src (source) of the image.
<img src="http://www.haymarket.com/images/brands/media/name/Stufftv_logo.gif"/>
To post your own images, you'll have to host them in something like flickr. This is what I use but doubtless there are others.
EDIT FROM MODS - When posting pictures, please format them to max 400 pixels wide to avoid them busting out of the forum frame. Huge pictures will be deleted.
Errr, use the following to place in an image in your post and limit its width.
<img src="URL to image" width="400"/>
Table
More complex. A two column table is defined like this
<table>
<tr><th>Column 1</th><th>Column 2</th></tr>
<tr><td>Row 1 Column 1</td><td>Row 1 Column</td></tr>
<tr><td>Row 2 Column 1</td><td>Row 2 Column </td></tr>
<tr><td>Row 3 Column 1</td><td>Row 3 Column </td></tr>
</table>
This html will display this
| Column 1 | Column 2 |
| Row 1 Column 1 | Row 1 Column 2 |
| Row 2 Column 1 | Row 2 Column 2 |
| Row 3 Column 1 | Row 3 Column 2 |
Simply copy the HTML above into your post and modify the text for your own. Unless you know what you are doing, I suggest that you do not add additional columns.
Yes and thanks.
Incidently, if there are any requests I'll take a look and add them to the first posting.
With new look forum on it's way I will be glad that we can format our post in the way it should be done and PJ, that was very good of you mate.
Agree. All going well, this primer should have a very short shelf life. Assuming that the software gets delivered on time. Hhhmmm. What's the chances of that then?
Updated OP to include a section on posting images. Should have put it in in the first place.
I think that Hhhmmm is apposite - AFAIK the forums will stay the same when the site gets upgraded, so your solid work on this tutorial will not have been in vain, PJP.
Andrew, this being the case, perhaps it would be better to get one of your "web monkeys" to do something a little more formal and stick into a page which is not a thread.
Alternatively, myself (and others) could submit updates to, say yourself, who could update the page rather than paying the web monkeys for something we can provide for ourselves.
Just an idea.
Heres one that I've used that may be worth adding to the original post. It allows a link to be opened in a new tab or window:
<a href="Your URL here, keeping the quotes" target="_blank">The text to display here</a>
This is superb. Well done you.
OP updated to include strike out, underlining, emphasising, sub and superscript
What's the difference between emphasising and italics?
Didn't the Italics play Romania tonight?. . . .Sorry couldn't help myself
Not a lot...but I like to give options.
still useful
Pity the forums dont have a sticky function...
You had some spare time on your hands then
Joking aside; thats all very useful stuff to have as a reference.
Oooh, look what I just did!
