Can Any Plumbing Experts Help ?
2 replies [Last post]
Jacko
Jacko's picture
Have come back from a week away to find that the hot tap in my kitchen is only working at 1/4 pressure and stops altogether after 2 minutes. The water is fully hot and all other taps in the house upstairs and down are working as normal.
Any tips on what I might be able to do to fix this before calling a plumber ? Thanks.
hammill
hammill's picture
RE: Can Any Plumbing Experts Help ?
I am not a plumbing expert, but fitting a new tap mechanism is not that hard (google should help). What sort of tap is it (ceramic or rubber washer)? Was it installed by a plumber (in which case if you look in the sink should find a valve on the pipe that will enable you to turn it off with a screwdriver) or an idiot? If it is only 1 tap that is not working, it seems likely that this is the cause. A whole new tap mechanism is quite cheap.
simonlewis
simonlewis's picture
This happened to me once, last year i think, i just called the housing association & they called a plumber, it took the plumber about five minutes to change the inside of the tap & the job was done. Smile
__________________
formerly known as slewis ---
simon's system
