Bits is bits
7 replies [Last post]
John Duncan's picture
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  Diamond 9.1 | Minx Xi | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
bigboss's picture
RE: Bits is bits
excellent!
__________________
fr0g's picture
RE: Bits is bits
Obviously needs an audiophile usb cable.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
AlmaataKZ's picture
RE: Bits is bits
 ... He said the anomaly is caused by Jbig2, an image compression standard.
Image compression is typically used to make file sizes smaller.
Jbig2 would substitute figures it thought were the same, meaning similar numbers were being wrongly swapped. ...
the article is not technical but from the above quote it seems that character regognition and lossy compression may be involved and if so this would have nothing to do with the 'bits is bits' part of things.
kena's picture
RE: Bits is bits
This "issue" is obviously not a fault since it's caused by a compression algorithm whos purpose is to make things smaller therefore changing a a 8 to a 6 is well within its design remit .. NFF  (No fault found) ..Smile
RE: Bits is bits
I have only just seen this reply, but...
F.
F.
S.
__________________
kena's picture
RE: Bits is bits
At least I took your post seriously!!
visionary's picture
RE: Bits is bits
John Duncan wrote:
I have only just seen this reply, but... F. F. S.
i've got one of those four foot snakes Wink
__________________
Sonos ZP90>Missing Link "Digit">Dacmagic>Chord Cadenza>Leema Tucana I>Van Damme UP LC-OFC>ATC SCM40s
Sonos Connect:Amp>Mission 760i and MA Radius 90HD in series
Sonos Play 5 x2, Play 3
