Best bang for buck PC upgrade.
39 replies [Last post]
fr0g
fr0g's picture
Ok, I haven't really kept up with CPU advances in the last few years.
My desktop PC is currently a socket 775 with Core2 Duo E8500 @3.16 GHz
I have Windows 7 Ultimate and 4GB of DDR2 (PC2-6400)
Will a memory upgrade to 8GB improve performance? That's cheap and simple.
Or would I be better upgrading CPU (and motherboard) and memory?
I wouldn't want to spend more than £300 or so on CPU and mainboard.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
yan121
yan121's picture
RE: Best bang for buck PC upgrade.
I recently instaled an ssd onto my pc which has lead to a significant increase in performance usually the limiting factor is the hdd run your windows experience index and that will tell you what is your slowest component
fr0g
fr0g's picture
I'm sure the HDD will be the lowest score, but I'm not sure I want to go to SSD right now tbh.
I shall check it now though.... Smile.....................
Indeed. 5.9 for HDD, 6.6 for CPU and memory and 7.2 for both gfx options.
I do wonder though if more memory would help. My main use is Photoshop (CS4) and I get a lot of slow downs with large multi-layered images.
__________________
davejberry
davejberry's picture
i may be wrong, but i was told 4GB of memory is the maximum that can be accessed by a 32bit operating system, are you running w7 32bit or 64bit?
__________________
LOUNGE: SONY KDL-46W4000; STR-DA2400ES & BDP-S350; SKY+; TOSH SD3010 DVD; PIO PD-F1009 MULTI CD; WII; KEF CRESTA 2 fronts,CRESTA 1 rears CRESTA CENTRE; BUDGET INTERCONNECTS & 79/42 STRAND OFC SPEAKER CABLES    BEDROOM: PANA TH42P-WD6;
f1only
f1only's picture
SSD would be the best upgrade without a doubt, it just sped my i7 laptop up by around 4 to 5 times. The HDD went from 5.9 on a 7200 rpm hdd to 7.8 on the windows experience using an SSD so is now the same as my Ram.
Start up times reduced & programmes installing, running, react a lot faster.
fr0g
fr0g's picture
64 bit. And yes, 32 bit doesn't support more than 4 GB (less really as 4GB is the maximum addressable memory).
__________________
fr0g
fr0g's picture
I guess. But right now startup and install times don't bother me really. What I want is photoshop to run more smoothly, which I'm guessing is memory and/or cpu... Smile
But I would like SSD at some point.
__________________
f1only
f1only's picture
How about a 120gb SSD about £80 for programmes they do run smoother, faster & a normal 7200 or raptor HDD for storage?
MajorFubar
MajorFubar's picture
Online
I don't think a faster CPU would increase the response of photoshop to be honest.  It's not a CPU-intensive app.  It's a memory intensive app.  When it comes to photo-editing, there  really is no such thing as too much memory.  The reason an SSD might improve things is because Windows caches to 'virtual memory space' on the hard-drive when real physical memory fills up, so in that respect a SSD would help because access to the 'hard drive' would be quicker.  But I still think you'd be better off with just simply more memory.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Cyrus 2 + PSX  > Cyrus tuner > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Technics SL-P777; Marantz CD63 mkII KI; Marantz PM66 KI; Nakamichi DR-1
John Duncan
John Duncan's picture
My first thought was an SSD for the OS, certainly. Easiest as well...
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  PMC DB1i | A secret shiny box | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
Xanderzdad
Xanderzdad's picture
Having just put an SSD into my Win7 64 bit system I would have to second it as an excellent upgrade.
In all honesty your budget would easily stretch to a Crucial M4 SSD (64 or 128Gb) and another 4 GB of RAM, so go for it.  Much better 'bang for your buck' than a new motherboard and CPU.
__________________
Home Cinema - Sky HD, Panasonic DMP-BDT210, Denon AVR 2808 (Pre amp into MF A3.2 Amp), Monitor Audio Silver S8, MA RS Silver LCR, 4x Q Acoustics 1010 + sub, Mitsubishi HC7000 HD Projector
Stereo - PC/NAS (Synology DS212J), Squeezebox Touch via CAT6, MF A3.2 Amp, Monitor Audio Silver S8
fr0g
fr0g's picture
Easiest?
4GB memory...Switch off, open case with the opening handle, plug in the ram, close case, switch on.
SSD. Transfer the bloody C drive to it somehow! Smile
(It's probably simple I guess, but it *feels* as though it may be a little long winded Smile )
__________________
John Duncan
Sorry, let me rephrase. I always presume that everybody who wants to have a fast PC has the most RAM their OS can support first before doing anything more radical. 4gig is a nice number for starters, my devs have 16 I think on win7 64 bit machines...
But presuming your processor is reasonably recent dual or quad core, the more obvious replacement would be the speed of the SSD for OS only. Obviously separating your OS plus apps and data might take some time, but better than motherboard or CpU at a guess.
__________________
6th.replicant
6th.replicant's picture
"Best bang for buck PC upgrade"?
A 2nd-hand Mac?  rolling on the floor laughing
MajorFubar
Online
Bad boy!  No spending-money for you this week  Tongue
__________________
Alantiggger
Alantiggger's picture
Mobo,Memory then your cpu.
The hard drive for most things it doesn't really matter although a lot of hardline gamers use an sdd for their os and just put everything else on an ordinary hard drive.
asus p8p67 pro is a nice mobo.... in fact look here :http://www.amazon.co.uk/Intel-Sandybridge-i5-2500K-Quad-Core-Processor/dp/B004FA8NX2/ref=dp_cp_ob_computers_title_0
and look near the bottom of the page to the part that says 'Frequently bought together' ... they're good parts and well worth the outlay.... a fast computer using them (similar to my own)        Cool
__________________
Lounge :  Samsung PS51E6500, Sony BDP S790, Virgin media XL, Onkyo  TX-SR508,
Tannoy Arena 5.1 with stands.(http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speakers/tannoy-arena-96472/review)
Bed : Panasonic PX70 and a Sony BDP-370 Blu ray Player.
So far  :)
