Air conditioning!
7 replies [Last post]
DistortedVision's picture
I've been away...studying for exams.
Its roasting hot in my study at home and its impossible to work. I'm looking at getting a portable air conditioning unit. The only option is to have the hose pointing out of the window. But surely having a window affects its performance?
What rating of machine do I require (BTU) for a room 4m x 5m?
Thank you!
Mark Grant's picture
Re: Air conditioning!
Hard to say without knowing how big the windows are and if south facing etc
As a rough guide about 150 watts per square metre of floor space, so 4 x 5 = 20 metres square multiplied by 150 = 3000 watts.
nearest size aircon unit would be 3500 watts or about 12000 BTU
Mobile units are fairly noisy but are cheap.
You could drill a hole in the wall and use a tumble drier vent kit for the hose or hang it out of the window. Making a cardboard cover for the open window to seal where the pipe goes out helps reduce the warm air getting back in.
A proper split system would be best and use less electricity but costs lots more.
If you do have a split system installed Daikin are the best make.
( I know about airconditoning as I install home cinema rooms for customers and often get involved with aircon work)
Mark.
John Duncan's picture
Online
Works for me...
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  Diamond 9.1 | Minx Xi | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
SteveR750's picture
This is cheaper...
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
Online
SteveR750:
This is cheaper...
"But the offer only stands today"
__________________
Mark,
The window is east facing and is ~ 1.35m x 4m.
The room is around 28-29C on average in summer because of the heat generated by lighting and my PC.
http://www.amazon.co.uk/Amcor-MF10000E-portable-air-conditioner/dp/B001E65CJS/ref=sr_1_1?ie=UTF8&s=kitchen&qid=1247049661&sr=8-1
Do you think its any good?
JG333's picture
I was looking at air con a while ago and ive seen a good site that sells cheap split units from £250 upwards and they also do heating aswell
http://www.vyair.com/scripts/prodList.asp?idCategory=2
Hope this helps!
unconditional's picture
What sort of window are we talking about?
If it's a sash stick the hose out and wedge a lump of polystyrene trimmed to fit the gap and shut the window on it.  (buy a sheet at a builders yard)
If it's hinged you could get a sheet of clear acrylic or perspex, cut the hole for the nozzle and fit/wedge into the opening.
While it doesn't have to be 100% airtight the less gaps the better the efficiency will be as negative pressure in the room will just mean the warm air you're expelling will flow right back in!  Also get some duct tape as cheap mobile A/C units normally have badly fitting exhaust hoses, if you have one feel the back to see how much warm air you're pumping straight back into the room!
