12 posts / 0 new
Last post
rendu's picture
Last seen: 10 months 3 weeks ago
Synology 112J vs 212J
Hello, I am considering the possibility of adding a NAS to my current setting. Based on comments from the forum, I am considering synology and looking at either 112J or 212J. The price difference between both is around 40 Eur. Apart from the fact that 212J allows 2 disks instead or one, are there any other major differences in terms of pure hardware? Also, any difference in terms of funcionality, this is, can you do the same with both?
1) Onkyo TX-NR818, Q acoustics 2050i, 2000ci, Wharfedale 9DS, Wharfedale 150W.  Synology NAS 112J, PS3, Harmony 650.
2) Marantz CR510 & Dali Ikon1
brendonw's picture
Last seen: 7 months 2 weeks ago
RE: Synology 112J vs 212J
You can do a direct compare 1 product against another here
http://www.synology.com/products/compare_spec.php?lang=uk
But the short answer to your question is yes functionality is the same Smile
brendonw's picture
You could always buy the 2 bay and 1 disk and add a further disk in a few months time.......
professorhat's picture
Last seen: 1 year 6 months ago
Recommended - 2 disks in RAID can protect you from a hard disk failure. You still need a backup copy in case of accidental deletion / corruption, but 2 disks in a RAID provides redundancy against hard disk failure and ensures all your data is still safe if this happens.
The owls are not what they seem...
rendu's picture
Thanks for all the input, I had already tried to do the comparison in the synology web but it only compares the hardware specs which to me are difficult to understand.
I still do not get clear whether both allow to do exactly the same things so e.i. whether there are any differences from the functional stand point.  Anyway, if I end up buying synology, I will probably go for the 212J even though I do not need 2 bays or even backup feature at this point.  However, I have just found another option which meets my requirements and it is much much cheaper and also has good reviews.
http://www.expertreviews.co.uk/network-storage/1289791/zyxel-nsa310
This one seems to do all I want (basically streaming movies and music) for much lower price and has got good reviews.
Any additional information which may help on the decission making process will be appreciated.
bigboss's picture
Last seen: 4 hours 2 min ago
You will find cheaper NAS drives from WD, D-Link, Zyxel etc. Synology's DSM software is the best & most user friendly out there.
Functionally, they will do the same thing, apart from the resiliency (note, not backup) I mentioned in my previous post.
rendu's picture
 That`s a good point thanks.
brendonw's picture
Synology all the way. The others are cheaper for a reason.
DSM is easy to setup and use.
Russ_64's picture
Last seen: 3 years 5 months ago
I totally agree with Synology all the way. My DS209j is still going strong and is a great iTunes and Media Server.
Paul.'s picture
Last seen: 1 week 4 days ago
Slightly left field suggestion, but how bout one of these?
http://www.amazon.co.uk/gp/aw/d/B00AHQUX86
I want one, just waiting for the cash back to come back.  They were down to £99 but missed it by a day due to odd cash back terms Sad
cheeseboy's picture
Last seen: 1 day 13 hours ago
they are excellent.  And you can stick vmware on it and run the synology software as well Smile  Or you can use it to run XBMC and do the whole shebang in one box Smile
Log in to post comments
