37 posts / 0 new
Last post
DocG's picture
Last seen: 3 days 4 hours ago
Sonos: Access to NAS denied
Hi all,
I finally decided to get me a Synology 213+ NAS. Firstly to have regular back-ups. I haven't suffered a crashing HDD so far, but that will inevitably happen eventually. So I want to be prepared.
Secondly, I would like to have my Sonos playing music off the NAS, so as not to have the PC on for that.
Now, I did manage to transfer the music to the NAS, but when I point Sonos to the new music library, access is denied, though I do provide the correct login and password.
Any thoughts on what I do wrong? :wall:
Bluesound Node2 - Devialet D120 - B&W CM7 (SAM)
spiny norman's picture
Last seen: 2 days 20 hours ago
RE: Sonos: Access to NAS denied
Is the music library set up as a shared folder, and do you have DLNA server software running on the NAS and pointed at the shared folder?
And so, on Feb 22nd 1966,...
The_Lhc's picture
Last seen: 2 months 4 days ago
You don't need any DLNA servers running on the NAS for Sonos to use it, it just needs a standard CIFS/SMB share. It's probably easier to just set the share to read-only for everyone rather than muck around with usernames and passwords, Sonos only requires read-only access, it doesn't write back to the library.
Thanks for clarification, Mr Collider
The_Lhc's picture
That's the main reason I went for Sonos, I didn't want to have to worry about any of that rubbish, Sonos makes it very simple.
DocG's picture
Well, apparently nog simple enough for me though!
I thought the clue was in the "shared folder", but creating a shared folder and moving the music to it doesn't solve the problem.
Changing all access to "read only" doesn't help either.
Any more tips?
M50 - D120 - LS50
The_Lhc's picture
How are you specifying the share name within Sonos?
DocG's picture
You mean: how I type the path to the network share?
That is: \\DISKSTATION\Muziek Sonos with "Muziek Sonos" being the name of the shared folder.
M50 - D120 - LS50
hammill's picture
Last seen: 1 week 4 days ago
I do not know if it is the problem, but I would not put a space in the folder name. That still causes issues with lots of programs - c:\Progra~1 will be familiar to many.
DocG's picture
Changed the folder name to Muziek_Sonos. Doesn't help.
Now in the Sonos setup, when I choose the path to the network share, the next field always asks for a login and password. Is that normal?
hammill's picture
Another thought, is the Sonos not resolving DISKSTATION to an ip address? Could you try the ip address instead?
E.G something like  \\192.168.1.100\Muziek_Sonos
professorhat's picture
Last seen: 1 year 6 months ago
When I set it up with mine, I installed the Audio Station package and then this automatically created a shared folder called Music. I then copied my iTunes Library to this shared folder and set my iTunes session to use that shared folder as its library so anything new ripped into iTunes automaticallty was populated there (you may not use iTunes, but you get the general idea on whatever music manager you do use).
I then set Sonos to look at this "music" shared folder - pretty sure it didn't ask for a username and password.
The owls are not what they seem...
If it's asking for a username and password, it sounds like the resolution is working okay.
hammill's picture
You would think that, but I have used software installers that automatically ask you for username/password without checking first if the destination exists. I don't know Sonos, so I am just thinking of things I have seen in the past that caused problems.
DocG's picture
Sounds like the way to go. Now let's see if I can bring that to a good end!
(is there an IT equivalent for "two left feet"? if so, that's what I have! Wink )
DocG's picture
OK, hammill. I'll first try the prof's suggestion. If that doesn't work - or I can't bring it to a good end - I'll give the IP-route a try. Thanks!
M50 - D120 - LS50
Pages
Log in to post comments
