Recommend me a NAS
5 replies [Last post]
MajorFubar
MajorFubar's picture
...ideally with a HDD already built-in.  I intend to mainly use it for music storage.  I don't think I need more than 2TB at most, and that's allowing for future purchases.
My home network consists of two Mac Minis, an iMac I7 and a Windows 7 laptop linked to a Netgear DGN2200 router via 500bmit homeplugs. Ideally I want the NAS to link via a spare port on one of the homeplugs, rather than direct to the router, because the router is not in an ideal place.
At the moment all my music is stored on the HDD of one of the Mac Minis, but I want to move it to an external NAS.
I just want something simple that my Macs will see, that I can mount with a script so each computer's iTunes can use it, same as they do now with the Music folder on my Mac Mini which is shared.
Thanks a lot.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
Hi-FiOutlaw
Hi-FiOutlaw's picture
RE: Recommend me a NAS
This one came to mind!
I could not buy this one as it didn't suport the SBT server.
Give a look!
http://m.wdc.com/en/product/280
Best REGArds
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
AnotherJoe
AnotherJoe's picture
I'd suggest looking at one of these Netgear ReadyNAS Duo V2.They support Apple File Protocol (AFP) and Itunes Server.
Its a 2-bay NAS for £98 (no drives included). So you could start by just adding a 2TB drive (£60) and then double up if you want to later.
You can also turn it into a PVR (FreeviewHD,FreesatHD or cable) using a USB dongle and record TV and share it to any other device on the network.
I would also recommend attaching the NAS directly to your router, and using the homeplugs only for end-clients. That way you dont reduce the available bandwidth when the NAS is serving multiple clients.
http://www.dabs.com/products/netgear-readynas-duo-v2--2-bay----no-drives...
http://www.readynas.com/?cat=102
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
MajorFubar
Thanks I'll check-out those options.
__________________
roger06
roger06's picture
I'm loving my Synology DiskStation DS212J. OK, you have to put the disk in yourself, but hey, are you old enough to remember putting film in a camera? ... that was harder.
__________________
Synology DS212J-> AppleTV->  rDAC->Naim Nait5i. Naim CD5i. Dynaudio Audience 52SE
Sony BDPS370 / YouView ->Yamaha RXV1065-> Pana TH42PX80B plasma.
MajorFubar
Haha Smile I still have film cameras, Olympus OM 1n & 4Ti, plus a Trip 35!
__________________
