22 posts / 0 new
Last post
Big Aura's picture
Last seen: 1 month 1 week ago
Getting the most out of my NAS drive
Hello all. I'm half luddite on my father's side, so need some gentle help...
What I have:
WD Mybook Live 1terabyte NAS drive
Ancient Dell XPS m1330 laptop - Window Vista, 160gb HD.
Sonos, Denon AVR, Sony BDP S760 and Sony 40w4500 LCD (not overly smart telly) and a Samsung Freesat HDR (bit smart, but not nearly smart enough), and Nexus 7 (2013)
My main issue is - the Dell is entirely full to bursting, there's no space on the HD. What I would ideally like to do is set up my system so that all new downloads bypass the Dell HDD and go straight onto the NAS drive, and for them to be available easily and wirelessly on the Dell (and on my Nexus 7). As things currently stand, I need to delete photos/albums or video clips in order to download even one album (the Foals better be better than Bon Ivor!). Once downloaded, I plug my Dell into the WD and manually copy the file across.
Am I asking the impossible, or is there a SIMPLE way to set up the NAS as the default memory (and perhaps even to sync phones and tablets to it also, so that they can easily draw on the NAS drive material - e.g. downloading films, as and when needed).
If anything I've written above seems confusing, happy to clarify.
Thanks!
BA
bigboss's picture
Last seen: 1 week 1 day ago
RE: Getting the most out of my NAS drive
Your WD NAS should show up as a hard drive on your Dell. Simply point downloads to it.
Or am I missing something? :?
hammill's picture
Last seen: 1 week 2 days ago
Big Aura wrote:
Hello all. I'm half luddite on my father's side, so need some gentle help... What I have: WD Mybook Live 1terabyte NAS drive Ancient Dell XPS m1330 laptop - Window Vista, 160gb HD. Sonos, Denon AVR, Sony BDP S760 and Sony 40w4500 LCD (not overly smart telly) and a Samsung Freesat HDR (bit smart, but not nearly smart enough), and Nexus 7 (2013) My main issue is - the Dell is entirely full to bursting, there's no space on the HD. What I would ideally like to do is set up my system so that all new downloads bypass the Dell HDD and go straight onto the NAS drive, and for them to be available easily and wirelessly on the Dell (and on my Nexus 7). As things currently stand, I need to delete photos/albums or video clips in order to download even one album (the Foals better be better than Bon Ivor!). Once downloaded, I plug my Dell into the WD and manually copy the file across. Am I asking the impossible, or is there a SIMPLE way to set up the NAS as the default memory (and perhaps even to sync phones and tablets to it also, so that they can easily draw on the NAS drive material - e.g. downloading films, as and when needed). If anything I've written above seems confusing, happy to clarify. Thanks! BA
Is it not as simple as mapping the NAS as a network drive on your Dell and then using that as the destination for downloads? Or am I misunderstanding the problem?
his dudeness's picture
Last seen: 1 week 10 hours ago
i dont no the wd live,but i would replace your laptops hd with a 500 g or even 1tb,really just a 2 min job,i did this recently with a hp which like you only had 160g hd and switched from vista to windows 7 premium its like a new laptop,with everything backed up to my nas.
lg55b6v oled,oppo uhd203,sr7008,tannoydc6tse,dc6,d6lcr,dc6,svs sb2000,humax hdr1000s,synology ds213j,nexus 5&7
Antony Brown's picture
Last seen: 9 months 1 week ago
Instaed of deleting photos etc. from your Dell, can you not kjust move all the photos and music etc. to your WD drive?  Then do as previously suggested and point all of your downloads to the WD.
MacBook > Geek Out DAC/Headphone amp > Klipsch X10i/Bang & Olufsen Earset3/Shure E3/Furutech ADL-H118
Samsung UE32D6100 > Arcam DV79 > Paradigm Sountrack
jlc3010's picture
Last seen: 2 years 12 months ago
you can have a look a this link :
http://wdc.custhelp.com/app/answers/detail/search/1/a_id/2676/c/130/p/247,335
it seems WD has some apps to upload download files from portable devices also.
http://www.wdc.com/en/products/products.aspx?id=280
Big Aura's picture
excellent. How does one "point" downloads? The NAS shows up when I click "Computer", but the default location is the Dell HDD.
In terms of replacing the Hard Drive - sure that involves being overy techy. There's a laptop repair place on my way home, I take it this is something that they can do easily/cheaply? (and how much should I expect to pay for parts and labour)?
thanks
hammill's picture
 For Vista, this appears to be the way to change your default download directory
Right click the download folder ( in user/ "your account" ) and select properties. Now select the "Location" tab. You can then write in whatever path you wish.
MajorFubar's picture
Last seen: 9 hours 44 min ago
No offence to the OP but some of us, including me, sometimes forget that a lot of people aren't even familiar with browsing around their computer's My Docs folders let alone anything else. I've lost count of how many times I've had to try and help people at work who can't find a particular document they saved days earlier. My first questions is usually "Well where abouts did you save it?" and the answer is often "On my computer of course", like I'd asked the stupidest question in the world. The follow-up question of "Yeah but which folder exactly?" gets nothing but blank stares. Even in 2014.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or RS-180
Big Aura's picture
Thanks all. And Major, yep - a bit guilty of that too. In my defence everywhere I've ever worked has had centralised document and file storage, so I've never had to store anything locally.
Re replacing the harddrive, I've just seen a video on uchoob and it seems even more simple that when I replaced the battery in my iPod.
For those in the know, will a new (uncrammed) hard drive mean my laptop boots up faster (currently takes 8-10 mins).
Also, are there better harddrives than others, e.g. http://www.amazon.co.uk/gp/aw/d/B008I02E30/ref=mp_s_a_1_1?qid=1390604140&sr=8-1%CF%80=AC_SX110_SY165
bigboss's picture
Remember there are only 2 manufacturers of hard drives in the world currently; Western Digital and Seagate.
Yes, your computer will get faster once there's more hard drive space.
You can speed it further. Check this.
bigboss's picture
Your Dell has a Seagate hard drive. Any 2.5-inch hard drive will do.
http://www.amazon.co.uk/s/ref=nb_sb_ss_i_0_3?url=search-alias%3Daps&field-keywords=2.5%20sata%20hard%20drive&sprefix=2.5%2Caps%2C220
Also, you can upgrade the RAM if you want it to be even faster.
http://www.amazon.co.uk/Komputerbay-667MHz-PC2-5300-PC2-5400-SODIMM/dp/B004LTAPPG/ref=sr_1_4?s=computers&ie=UTF8&qid=1390608891&sr=1-4&keywords=sodimm+ddr2
Big Aura's picture
thanks BB.
I actually use most of those tricks to speed it up (CCleaner and I used to degrag often, until my HD got too full - a defrag with minimal free disk space takes about 35hrs!).  Until I find a "replace RAM easily" youtube link, I'll stick with upgrading the hard drive.
Just so I'm sure I'm on the right track - this (which is Seagate/Samsung SATA) should do the trick?
http://www.amazon.co.uk/Samsung-Seagate-inch-5400RPM-Drive/dp/B007NVGWV0/ref=dp_ob_title_ce
thanks again
visionary's picture
Last seen: 2 months 3 weeks ago
Big Aura wrote:
thanks BB.
thanks again
The on-line manual for the Dell shows you pictures of how to do it clicky
If you go to a site such as www.crucial.com they can advise the correct memory to buy
jonathanRD's picture
Last seen: 3 hours 25 min ago
Big Aura wrote:
excellent. How does one "point" downloads? The NAS shows up when I click "Computer", but the default location is the Dell HDD. In terms of replacing the Hard Drive - sure that involves being overy techy. There's a laptop repair place on my way home, I take it this is something that they can do easily/cheaply? (and how much should I expect to pay for parts and labour)? thanks
I've upgraded my RAM on my desktop computer and will attempt to most things myself. But after the cooling fan started playing up, I wasn't exactly sure which replacement would work or fit (as an alternative to the Dell part). So I went along to a local computer shop who also do repairs. I had a rough idea what the cooling fan would cost, so when they quoted a figure that was about £20 more - I quickly said yes, please get on with it.
The point is, there's no harm in going and asking for a quote - especially if you know how much the individual parts are you want to replace. It might save you a lot of time and stress.
Rega Apollo > Exposure 3010S2D pre & 2 x 3010S2 power > RS5
Sony BDP S480 Onkyo TX-NR609 MA BX1, BX2,Centre,BXFX BK XXLS400DF
The_Lhc's picture
Last seen: 2 months 2 days ago
Big Aura wrote:
thanks BB.
thanks again
So, how are you planning to copy the contents of the old drive to the new one?
Replacing RAM is a piece of pie, usually. Open a hatch on the underside, take the old stuff out, put the new stuff in, close the hatch.
Pages
Log in to post comments
