16 posts / 0 new
Last post
Ravey Gravey Davy's picture
Last seen: 6 months 3 weeks ago
Bye Bye Readynas - Synology next?
So the Ready Nas Duo is knackered.Will not react to factory reset and intermittently states corrupt root so I think it is time to go another route.
I am thinking Synology DS213J or 214 - are there any other "friendly" devices I should consider? (the Readynas was not friendly really)
There are currently no Apple or Sonos devices involved- streaming is done through Pure Sensia,laptop or BDP.
bigboss's picture
Last seen: 2 days 17 hours ago
RE: Bye Bye Readynas - Synology next?
I've got Synology. It's one of the most user friendly devices out there. Also look at QNAP. Andrew Everard has written a nice blog on setting QNAP up.
Whatever NAS you choose, I would highly recommend Western Digital red drives which are designed for NAS use.
Thanks BB- I'd forgotten about that blog. I've found a Qnap for a similar price and then I discovered this review (same model as I found) so it looks as though it's even easier than the Synology and with a better processing spec.Moves into first place now.
bigboss's picture
I would keep both Synology and QNAP at the same level. Both are brilliant.
Xanderzdad's picture
Last seen: 4 days 9 hours ago
I would second the Synology as they provide a wide variety of quality 'apps' that are regularly updated.  I'm not sure if QNAP offer such a good range.
chrisr1718's picture
Last seen: 19 hours 21 min ago
Just got myself a Synology DS213j with two WD red drives, setup is easy peasy. Copied everything over from my external hard drive, just drag & drop, and it was surprisingly quick over the network. Create folders for the family and mapped them so they can be accessed via Windows Explorer. All very simple, you don't have to be an IT expert!
HiFi: Project Expression(upgraded), MarantzCD6000OSE, Cyrus2+PSX, DenonDNP720AE, NakamichiCD2, TannoyR3, Chord Crimsons, DS213j
AV: Samsung 48" ,SonyS7200,DenonX2200,TannoyHTS101+JamoA102's
Feral's picture
Last seen: 1 month 2 weeks ago
I've been using the DS213J to stream flac rips of my collection to the SM6 wirelessly with no issues.  very friendly and easy to set up, bought the drive speparately and just a matter of open the case and slot it in, couldn't be easier.
One note of caution.  The DS213J uses a different processor to other models and although has floating point processing will not work with PLEX for transcoding video.  I'm playing with a PI and XMBC to stream and transcode the video but in hindsight i might have considered a different nas.  That said, there are a lot of features such as clould access, the ability to stream from your nas to your mobile device and a ton of other stuff i've not explored yet.  I am very happy with the performance as far as music is concerned and also used andrews blog and invested in the bliss software which i found invaluable.
LG 65UH950V/AVR2300W/Q7000i/Synology DS213J/CA640Av2/CA640Cv2/CASM6v1/Project Debut III USB/Monitor Audio Bronze BX6
Is there anyone other than Andrew out there with a Qnap?
scene's picture
Last seen: 2 days 19 hours ago
Argh! My fellow readyNAS user - gone!
I must admit, if my readyNAS blows up I'll probably gor for a synology - want a 4 or 5 disk cabinet next time - one that takes at least 4TB disks as well.
Look forward to seeing how your search goes.
AV: Marantz SR7009; Monitor Audio RS-LCR, Silver 8i, RXFX; BK XXLS400 Sub; Pioneer KRP500a; Sony BDP-S760
HiFi: Arcam A85; AE Compact 1; Arcam DV79 (as CDP), ProJect Debut II
Have you got a secondary usb backup ( As often said by the_lhc it is a storage device not a backup). If not,do it now. My issue on the ReadyNAS is a corrupt root isssue and you cannot necessarily retrieve the data on the disks.If yours is still working, you can still take out a 5 year warranty with Netgear which includes disks, and it costs £175 approx.
kena's picture
Last seen: 1 year 4 months ago
 I've a ReadyNas Duo Scene so your not alone.
Must do a current backup not done one for a bit, any inkling on what caused your root access prob?
cheeseboy's picture
Last seen: 1 week 1 day ago
if you're using XBMC you won't need to do any transcoding as XBMC plays pretty much all formats natively.  You'd only need to transcode if you are streaming to say a PS3 where it has to be in a certain format.
Amadeus1756's picture
Last seen: 2 years 9 months ago
I bought Synology because they have UK support.
grimmers's picture
Last seen: 2 weeks 2 days ago
hi,
    i have both a synology 214se and a qnap 212e,inatially the synology was the easyast to the set up and get up and running with dsm5, but over running for over a few weeks, the qnap has in it's favour better build quality and more apps,plus  it comes with plex,the hardest thing was getting logitech media server to work with them, but i think that was down to my lack of knowledge about servers, indeed l.m.s is supported by both units.The synology is the one to buy if you want to set it up and forget it easyily and the qnap if you spend a extra few hours to getting it how you want things how you want them, and are a constant fidler, the only drawback with the qnap is the software runs very slow,this is my second qnap in 12 months and the software ran just as slow on the older one, but it looks like there will be an imminent software update for the qnap.I would wholehearterly agree with bigboss and others on this forum to use wd red drives in which ever nas unit you buy. Smile
MrBrickFish's picture
Ravey Gravey Davy,
I also use QNAP.... a TS-412, currently with 2 WD 3TB drives leaving 2 bays free, (the idea was that I would fill these as and when larger drives become mainstream).... Despite an IT background, I find hard to comment on NAS's.... the devil is in the detail... just looking at the ticks in boxes on the spec sheets, does not really tell you the detail of how well the features actually work. You have to live with the thing.
I'm generally happy with the QNAP, but feel I could do a lot more with it via the installable apps. Although without experience of other brands and models it is hard to comment upon or recommend.
Sean
Thanks for all the input. I think the Synology 213j gets it for the extra £50 over the 214SE . There doesn't seem too much diffference in the software v the Qnap for my use so I might just take the plunge this afternoon- especially if Liverpool win- I will need retail therapy.
Log in to post comments
