Back up storage
13 replies [Last post]
shooter
shooter's picture
I really need to get my music backed up on an external drive, it took a long time to get the music ripped and i dont want to loose the lot.
Spotted one of these Hitachi Touro HD's on Amazon at a reasonalble price, would it do the job?
http://www.amazon.co.uk/Hitachi-Touro-Mobile-External-Drive/dp/B006DZKEA...
RobinKidderminster
RobinKidderminster's picture
Online
RE: Back up storage
From pc / laptop? Any usb drive will do the job
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
shooter
shooter's picture
RE: Back up storage
From Mac?
bigboss
bigboss's picture
Online
RE: Back up storage
__________________
BigH
BigH's picture
RE: Back up storage
That should be OK, I'm not a Mac user so don't know about that part, it is really good price, I just bought a Seagate 1TB for £74.
__________________
Marantz 63SE AVI ADM9RSS
CnoEvil
CnoEvil's picture
RE: Back up storage
bigboss wrote:
Not sure about the HDD you've linked, but I can recommend these for your Mac: http://www.amazon.co.uk/Western-Digital-Passport-Portable-Drive/dp/B007U... http://www.amazon.co.uk/Western-Digital-Elements-Portable-Drive/dp/B005A97APO/ref=sr_1_3?s=computers&ie=UTF8&qid=1357039302&sr=1-3
Agreed. I use the WD Elements, as in the second link.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
shooter
shooter's picture
RE: Back up storage
Cheers guy's, i will take a punt on the Touro and see if it works out, worst case senario would be a return and to get a tried and tested drive.
shooter
shooter's picture
RE: Back up storage
Just reading through some on-line info it looks as though the HD will need to be reformatted for Mac use.
It goes on to say that its a simple process but i have no idea what to do. Is it simple and would i need some kind of OS to put on it?
bigboss
bigboss's picture
Online
RE: Back up storage
__________________
bigboss
bigboss's picture
Online
RE: Back up storage
If only Mac, check this:
http://store.apple.com/uk/browse/guide/storage
"With hard drives, do I need to worry about formats—Fat32 vs. HFS+?
Not really. Fat32 is a Windows-based format, while HFS+ was developed by Apple for use on the Mac. A Fat32-formatted hard drive can be use by both Mac and Windows computers, while HFS+ hard drives can be used only on a Mac. The Apple Online Store sells many hard drives that are pre-formatted with HFS+. Any of these can be reformatted with Fat32, though, if you want to use them in cross-platform environments. (You'll need to back up any files before reformatting, however.)
Can I use either drive format with Time Machine?
Time Machine only works with HFS+-formatted hard drives. If you want to use your external hard drive with Time Machine, the hard drive must be formatted in the HFS+ format. (Again, remember to back up files before reformatting.)"
__________________
bigboss
bigboss's picture
Online
RE: Back up storage
Formatting is easy. Simply right click on the drive (or click with 2 fingers on the track pad, as it's Mac) when connected to your Mac to bring up its menu & select "format" or similar.
__________________
BIGBERNARDBRESSLAW
BIGBERNARDBRESSLAW's picture
RE: Back up storage
I just bought a 2TB Seagate for £69.99, so your price isn't as good as you thought, sorry.
http://www.currys.co.uk/gbuk/seagate-expansion-sgr39211-external-hard-dr...
__________________
LOUNGE:  Panasonic TX-P50GT50 / Panasonic DMP-BDT120 / Yamaha RX-A2020 / Q Acoustics 2020i (front) / Q Acoustics 2020 (rear) / Q Acoustics 2000Ci / Q Acoustics1000Si / Pro-Ject Debut 3 / Sky HD
BEDROOM:  Samsung LE32C450 / Sony BDP-S360 / Echostar HDS-600RS
IN THE ATTIC:  Cambridge A4 Integrated Amp (not working) / Technics SL-PG 490 CD Player / Teac V-1050 Tape Deck / Morduant Short MS-20i Pearl Edition Speakers
Paul.
Paul.'s picture
RE: Back up storage
Shooter, you may want to get to know the disk utility tool. It's a simple yet powerful disk management tool found in the utilities sub folder of your applications folder Smile
http://macs.about.com/od/applications/tp/usingosxdiskutility.htm
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
shooter
shooter's picture
RE: Back up storage
Cheer BB, looks straight forward enough i guess so i'll be ordering one this eve.
Top info Paul, its about time i took some time out to go over the HD's here, im sure i've done it befor but it would have been along time ago. The start up seems a bit slow and lately, mayb this will cure that.
