4 posts / 0 new
Last post
davlee's picture
Last seen: 3 years 8 months ago
UPnP problem
I wish to play MP3s from my Windows 7 laptop to my Cambridge Stream Magic 6 via UPnP. I have installed XBMC and the Stream Magic recognises this with no problem. After the Stream Magic completes it's loading cycle from the XBMC library on my laptop, all I get is "empty".
Can anyone advise what I am doing wrong please?
Thanks,
Dave
Andrew Everard's picture
Last seen: 3 years 3 months ago
RE: UPnP problem
I think I'd give Twonky Server a go on the PC – if nothing else, to check whether it's a server configuration problem or a connectivity one.
AnotherJoe's picture
Last seen: 1 year 9 months ago
RE: UPnP problem
You need to make sure all devices on your network are allowed to access the pc
Control Panel -> Network and Internet -> Network and Sharing Center -> Advanced sharing settings
- Make sure Network Discovery is on.
- Under media streaming, click on choose media streaming options
Change show devices on to All Networks and click Allow All. If a popup appears select Allow all computer and media devices
Click OK, exit
davlee's picture
RE: UPnP problem
Thanks Another Joe,
Changings settings as you advised has resulted in the Stream Magic now being able to load and play all music files in the Sample Music folder which is in Libraries. It won't load any other folder but will recognise & play anything I place in the Sample Music folder.
Is anyone able to help with getting the Stream Magic to recognise MP3s in other Music Library folders please?
The Stream Magic still won't access MP3s stored on the laptop via XBMC
Log in to post comments
