Uniti Lite best low budget solution for my system?
Hi all!
My hi-fi consists of a pair of Triangle Celius 202, a primare cd21 & an integrated amplifier primare a30.1. I would like to be able to stream music from a NAS in the same quality in terms of sound or slightly better than i do now in my current system. Given the fact that in 5 years time my amp will be 15 years old, is the purchase of Naim's Uniti Lite the best low budget solution for my hi-fi system now?
Thank you in advance,
Harry
The Uniti Lite is an all-in-one so if you are looking at ultimately retiring your current CDP and Amp to reduce box count then yes, it's a solution.
If you're looking to keep your current CDP and maybe upgrade your Amp then something like the CA Stream Magic 6 or Naim ND5 XS may be more appropriate
Anyone please?
You started two identical threads...
http://www.whathifi.com/forum/hi-fi/help-is-uniti-lite-best-low-budget-solution-for-my-system
(You even replied in the duplicate one yourself.)
I have no idea why people do that. Just leads to confusion.
Chebby you will have to excuse me...i'm new at this stuff!
Scissor_digits thanks for your answer!
but can i ask you about a highly subjective matter?
i hear also music (from time to time) from my pc to amp(without external dac)
If perfect sound is 100 let's say points and my current system (cd21 & primare a30.1) for convenience purposes is 50...what would you mark the sound
1. From pc to my amp (without dac) &
2. From Uniti Lite to my amp
Thanks again,
Harry
We've had some people post up to 4 or 5 duplicates at one time.
I used to think it was just attention grabbing. Maybe there is some site software glitch that only affects new posters.
I think it's just people expecting their post to appear as soon as the page reloads (which isn't unreasonable) but it actually takes a couple of minutes, so they repost it, then that doesn't appear immediately, so they do it again, and again.
But in this case if the OP replied to his own original thread before starting this one (I don't know if he did), well then...
Anyone please?
