4 posts / 0 new
Last post
skippy's picture
Last seen: 4 weeks 10 hours ago
sonos S/PDIF splitter
I'm looking to change my system in the near future.
As a starter I'd like to know if I can or if you can buy a splitter for the coax output on the Sonos.
Basically I'd like to keep the coax cable I have running to the AV amp in the basement and add a 2nd which would run into a DAC and then possibly into actives on the main floor.
The two systems would run simultaneously so I'd be interested to know if it could be done or whether I have to totally rethink this... The optical out is feeding a pair of Mackie actives in the garage.
Thanks upfront.
visionary's picture
Last seen: 4 months 1 day ago
RE: sonos S/PDIF splitter
I don't know if you'd have issues with impedance if you try to split the co-ax (someone cleverer than me should know). Could you use an optical splitter on the other output instead? I've used an optical splitter/switch on mine without problem in the past.
skippy's picture
That'd work, didn't realize you could do that.
Can you run both at the same time?
You don't have a link do you, or is it an Amazon search?
visionary's picture
Amazon is where I got mine, search for Toslink splitter or clicky
Log in to post comments
