5 posts / 0 new
Last post
EMPIRIX's picture
Last seen: 3 years 10 months ago
Sonos connect AMP?
What do you guys think of the connect:amp?
I was contemplating buying seperates but i do want wifi streaming and well the price rises sharply adding on a wifi module.
I was contemplating the connect:amp with some monitor audio bx2s.
Also, is it necessary to have an airport express for airplay - i heard rumblings of an update that bypasses this need?
Finally, anybody recommend a turntable to use with the connect, preferably with mp3 converter?
Many thanks
bigboss's picture
Last seen: 1 week 3 days ago
RE: Sonos connect AMP?
You don't need AirPort Express for AirPlay. After a recent Sonos update, you can play songs from your iDevice directly via Sonos, just like AirPlay.
The_Lhc's picture
Last seen: 2 months 3 days ago
*Almost* like Airplay, you can only play songs stored on the iDevice, you can't redirect Spotify audio or any other streaming audio to Sonos without using an Airport Express.
bigboss's picture
Yes, but a lot of streaming audio services like Spotify are on Sonos in any case.
Frazer1979's picture
Last seen: 3 years 7 months ago
I think it might be worth pointing out that not all i devices will stream to Sonos. It would be worth checking out the devices that will give you the option of "this iphone/ipad/ipod" before jumping on it if it is an essential requirement. The device will have to have the latest ios and be one of the later generation of i device for it to work but when it does it works very well.
I really hope this helps Smile
Log in to post comments
